need spark
Old Jul 2, 2011 | 09:48 AM
maz5150's Avatar
maz5150
1st Gear
Default need spark
Rebuilding a 93 fxr from ground up, got the engine in and wired up, but have a weak spark, ignition is good, coils, wires plugs, batt new, wiring is correct, but not to sure about the voe switch.
Was wondering what could be giving me week spark.
Starting at the ground, where should i look next.
Old Jul 2, 2011 | 10:57 AM
OldMike's Avatar
OldMike
Well, you need a good, fully charged battery.
How are you determining that the spark is weak?
Old Jul 2, 2011 | 03:25 PM
maz5150's Avatar
maz5150
1st Gear
batt is new and fully charged, i've been grounding the plug off the head, seeing some faint spark. but nothing close to what i should be getting.
Old Jul 2, 2011 | 04:34 PM
OldMike's Avatar
OldMike
If you have an owners manual, maybe to a coil check.
Old Jul 2, 2011 | 06:11 PM
maz5150's Avatar
maz5150
1st Gear
Coil is brand new.And getting the correct amps at the contact posts.
Old Jul 3, 2011 | 01:58 AM
superrooster2003's Avatar
superrooster2003
new coil doesn't mean good coil
Old Jul 3, 2011 | 07:27 AM
OldMike's Avatar
OldMike
Yep, you could try the old coil.
Old Jul 3, 2011 | 08:04 AM
maz5150's Avatar
maz5150
1st Gear
coil is fine, just ran it on another bike.
Old Jul 3, 2011 | 08:39 AM
JohnnyC's Avatar
JohnnyC
Battery issues come into play when you can confirm a good battery with a solid deep charge but may have corroded / faulty / loose connections in the circuit.
You may need plug wires, or fresh plugs.
If the voltage to the coil is correct, even under the load of the motor starter running, and you only get a weak spark with fresh wires and plugs, then you have to go "upstream" from the coil.
You have a cam sensor on that EVO, and a stock factory ignition module that send the "spark signal" to the coil. If they are not functioning correctly the duration of the spark, or coil charging, could be effected and only create a weak spark.
Both are tough to test unless they completely fail. Often they falter under heated conditions. Check the supply voltages.
Old Jul 3, 2011 | 09:57 AM
OldMike's Avatar
OldMike
I was also thing maybe a bad ground somewhere.
