master tune question
Old Jul 4, 2011 | 10:24 AM
j88j's Avatar
j88j
Default master tune question
I have an 07 fxd with joker machine air intake, v&h short shots, woods tw555 cams,woods directional lifters and screamin eagle pushrods. I just installed the tts and the base map im using is caa176-03. I was just wondering if anyone else has a similar setup and what map and adjustments are working well.
thanks in advance
Old Jul 4, 2011 | 01:53 PM
sacto95827's Avatar
sacto95827
thanks in advance
You can use the V-Tune app to customize your map to your set up. It works really well. I did four runs with the V-Tune and dialed in a map that pushed out 78 HP and 92 lbs of torque. I then got it dyno'd and reached 82 HP and 98 lbs of torque...so you can see there wasn't too much difference from the V-Tune runs.
koolbreez
The Dyno Room
Feb 18, 2019 10:44 AM
472viper
26
Jan 6, 2015 04:23 PM
sorider
Mar 4, 2009 08:42 PM
Glyde
Jul 24, 2008 05:57 PM
gapwl3
May 15, 2008 04:06 AM
