Offset rear wheel FXD????
Old Jul 9, 2011 | 04:28 PM
BlackDyna's Avatar
BlackDyna
Stage IV
Default Offset rear wheel FXD????
My 2005 FXD has a slight(?) offset to the left of 3/8-1/2 on the rear wheel. Is this normal? I have had no problem with it for 7500 miles. It rides fine, handles fine etc. I was thinking of bumping up to a 180 tire but with this offset it won't work. Waddaya think?
Old Jul 9, 2011 | 04:32 PM
Stiggy's Avatar
Stiggy
I've never seen a Harley that didn't have an off set rear wheel....
Old Jul 9, 2011 | 04:56 PM
BlackDyna's Avatar
BlackDyna
Stage IV
So this goes back to the issue of the wider tire. With this offset, does a 180 tire still fit with every thing else the same?
Old Jul 17, 2011 | 08:43 AM
Deadwood's Avatar
Deadwood
I'm not sure about an 05 FXD but my 00 FXDX will not allow a 180mm rear from the stock 150mm so I've been told. My rear is offset to the left whcih I heard is done to counter balance the gearbox.
Old Jul 17, 2011 | 08:52 AM
8541hog's Avatar
8541hog
Then you have never seen mine.
To the OP, have you checked your alignment on the wheel? Mine did look that way until I aligned the rear wheel, now it is perfectly centered. I run a 160 on the rear of my 05 without a problem. It is possible to do a 180, but from people I trust that I have spoken with, you need an 18" wheel and you need to clean up the inside of the fender. Such as using t-nuts so the surface is flush, planishing the lip on the inside of the fender. It is not an easy, just swap tires and done, but it is possible. A 160 would be an easy swap.
Old Jul 17, 2011 | 10:02 AM
OldMike's Avatar
OldMike
160 is all you can do on an 05.
slickster5150
May 2, 2015 09:58 AM
springr
May 15, 2014 04:59 PM
LarryAck
Aug 13, 2013 04:51 PM
RFG40901
Screamin Eagle CVO Models
Nov 3, 2010 06:50 PM
p51bombay
Sep 13, 2010 06:45 PM
