Heat Wraps
Old Aug 3, 2011 | 05:34 PM
The13Fallen's Avatar
The13Fallen
I wrap my pipes. I use the automotive wrap from autozone and use the black silicone spray to color them. The heat off the pipes is gonna depend alot on how close you overlap the wrap aroun the pipe. I love the look, gives that old bobber look to me. If you do yourself acouple of tricks you might wanna use; I always set the wrap in a bucket of water for 15 minutes before I wrap with it; Sometimes I will use a spray adhesive on the pipes if they a difficult pipe to wrap; another is I use hose clamps instead of the thin tensioners that come with some wraps. Once I get the wrap done, I let it dry it the sun, then spray it with the silicone, let that sit for a second, then bolt them up start the bike and let it run and dry them out
Old Aug 3, 2011 | 08:33 PM
ratbob81's Avatar
ratbob81
I used the new dei titanium wrap, easy to install and no need to coat anything or soak them. Use hose clamps for a better grasp.
Old Aug 4, 2011 | 04:58 AM
cscoffee's Avatar
cscoffee
Default Exhaust
The13Fallen-what two into one exhaust is that? It is sick!!
Old Aug 4, 2011 | 06:37 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Originally Posted by chevypilot
HOGrida..... have you wrapped over the heat shield before? I was thinking of doing this, but thought it might not turn out right or ruin the pipes..
I have not done this. When I had my ShortShots I wrapped without the heat shields and regreted it once I saw how much better they looked wrapped with the HS left on. I now have a Thunder Header which doesn't have full heat shields.
Old Aug 4, 2011 | 08:01 AM
The13Fallen
Its a custom exhaust that american classic motors has. The good thing I didnt have to alter or fabricate anything they matched up perfect. The pipes come with, all the needed hose clamps, mounting bracket for the bottom of the pipes, and heat shields too, but I prefer wrap. I got bored with my others and wanted to change, and found these on ebay, and thought they are different and make getting my oil dip stick alot easier.
Col.Squirt
Sep 3, 2010 06:57 PM
Rik84
Exhaust System Topics
13
Jul 9, 2010 01:43 PM
millersbobber
Feb 6, 2010 10:29 AM
amish
Aug 16, 2008 09:37 AM
boutellepc
Jun 21, 2008 12:45 PM
