2-up seat installation...easy question
Old Jul 16, 2011 | 10:14 AM
canadagrown's Avatar
canadagrown
Default 2-up seat installation...easy question
I'm switching from my stock street bob solo seat to a two up seat. How do I bolt the 2-up to the fender? There is a nut built into the fender for the solo but the hole I put the bolt into for the 2-up has no nut. Can I somehow pull the nut from the solo and use it in the hole for the 2-up? Or do I have to order one from the stealer? Thanks alot.
Old Jul 16, 2011 | 10:37 AM
PMB3's Avatar
PMB3
There is a clip holding the nut on you take it off and move the nut to the back hole and put the clip back on.
Old Jul 16, 2011 | 10:50 AM
'09fxdb's Avatar
'09fxdb
That's how I did mine...
Old Jul 16, 2011 | 11:11 AM
Fridge's Avatar
Fridge
Little tip, to get the captive into the rear fender slot it has to be fed up from underneath.
Easiest way is to run a cable tie through it and use that to pull it up and into the hole so you can clip the circlip on.
Old Jul 16, 2011 | 11:50 AM
canadagrown
Is it easy to take off the clip thats holding the nut on? I don't want to break it...i have a knack for breaking the plastic pieces on the bike....
Old Jul 16, 2011 | 12:09 PM
fskitch's Avatar
fskitch
Might not be a bad idea to have the retention nut, plastic washer and screw for the rear fender hole. Retention nut is soft brass and washer is plastic....I keep a couple in my spare parts drawer, I switch solo two two up a lot. Retention nut Part #7488, plastic washer part #7489A, screw part #2952A. I think 5 bucks or so for those parts.
WoodButcher66
Sep 30, 2017 09:09 PM
apblingAEW
Jun 20, 2015 09:35 PM
blueangel73
Aug 7, 2014 09:09 PM
Melonbob
Aug 19, 2011 02:45 PM
wholbein
Feb 8, 2010 08:07 AM
