103C.I vs 106/107
Old Jul 24, 2011 | 06:34 PM
Blackbobber's Avatar
Blackbobber
Default 103C.I vs 106/107
I have read a lot of threads on here about the builds they don't seem to be much different in power. Give me your setups with TQ and HP. I am trying to decide the cost isn't much different so I am trying to make up my mind. Thanks in advance.
I already have 94hp with 100TQ.
Old Jul 24, 2011 | 07:35 PM
thedonthere's Avatar
thedonthere
Dude, just add a 30 tooth pulley...........you have plenty of power
Old Jul 24, 2011 | 07:39 PM
Brewtality's Avatar
Brewtality
107" from Hillside, see sig
Old Jul 24, 2011 | 08:12 PM
redrubicon2004's Avatar
redrubicon2004
No such thing!!
Mine is a 4 1/8" bore 4" stroke 107" and made 115hp and 122tq the last time it was dyno'd. I bumped up the compression and added nitrous so its going back for a tune next week.
Old Jul 24, 2011 | 08:14 PM
missedem's Avatar
missedem
If you want more power check out the fuel moto 107 build and OdiousBarbarian sounds like he is having great luck with his hillside 107 build as well. Those are good numbers he has. I am just running the stock setup at the moment with pipes and EFI box so I am not anywhere near the numbers you have even now. Good luck. Post results when you decide on your build.
Old Jul 24, 2011 | 08:56 PM
Blackbobber
I have a V&H comp pipe with V&H A/C and a redshift 575 cam. The cam isn't exactly what I wanted but gave me good power. I will probably change the cam and exhaust eventually.
Old Jul 24, 2011 | 09:58 PM
jpace024's Avatar
jpace024
Hillside 107" build, see sig for specs.
Attached Thumbnails 103C.I vs 106/107-107sae.jpg
Old Jul 25, 2011 | 04:50 AM
HemiOrange's Avatar
HemiOrange
I agree with that! I've also seen some great numbers with a 103". It's the builder that seems to make the difference.
That Fuel Moto build you mentioned, if I recall, was about $2800 and included the exhaust, programmer and A/C. Pretty reasonable in my book to take a factory stock bike to that level, which was about 120/125 HP/TQ if my failing memory serves me correctly. I wish someone could bring that few month old post back up. For sure don't trust my recollection!
Old Jul 25, 2011 | 05:26 AM
Blackbobber
Did you have any crank work done? I heard over 120tq you have to do crank work?
Old Jul 25, 2011 | 06:01 AM
crackerbiker's Avatar
crackerbiker
See my signature: Cycle Rama 575 cams and build using Revolution Performance 107 cylinders and Wiseco pistons
