front end?
Old Jul 27, 2011 | 12:09 PM
rooti's Avatar
rooti
it's due for a fork oil change, he can go one step thicker to firm it up a bit.
The obvious tire pressure check and steering head bolt would be the place to start
Old Jul 28, 2011 | 06:15 AM
Steve06FXDB's Avatar
Steve06FXDB
Thanks Fellas!!
Old Jul 28, 2011 | 07:27 AM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Elwrong66
Hi everyone, my buddy has a 2006 dyna low rider and all of a sudden when he rides he can feel every little bump in the front end? any idea what it might be? No signs of fork oil leaking out. Maybe a fork spring broke?........thanks for the help.
How are his riser rubber bushings? Riser bolts tight?
Old Jul 28, 2011 | 05:32 PM
Steve06FXDB
Riser bushings do have play. I can move my bars back and ahead a little bit but the riser bolts are tight. I guess im going to have to order new bushings
Old Jul 28, 2011 | 06:18 PM
WS6 Formula
That's normal, unless there is too much play to cause the riser to hit the triple clamp.
Old Jul 28, 2011 | 08:24 PM
DCLXVI's Avatar
DCLXVI
I have an '06 and it has been doing the same. My fork oil is fresh, I change it when I replace the tires. I adjusted the stem nut today and after a short test ride it was gone. I recall reading about a service bulletin that may have affected the '06 models, maybe requiring a different bearing but I'm not sure. The adjustment took about 15 min so I'll see how it holds up.
Old Jul 29, 2011 | 05:52 AM
Steve06FXDB
DId you just follow the procedure in the service manual?? I am going to check mine after work today
RWNMC
Sep 24, 2014 09:11 PM
harleyowners0709
Sep 9, 2012 05:38 PM
stang2811
Apr 7, 2008 07:27 PM
Granty666
VRSC Models
Apr 20, 2007 08:42 PM
toby34
Aug 2, 2006 08:11 PM
