Exhaust Flange gasket
Old Jul 27, 2011 | 07:57 PM
Joat Mon's Avatar
Joat Mon
Stage II
Default Exhaust Flange gasket
Hi all. My first post here. I need to replace the exhaust gasket at the head on my front head (nuts disappeared). I bought a new gasket from a local shop. They said it would fit but when I was testing it for fit I got it to go into the head fine but it does not slide over the part of the pipe that fits into the head. Is it suppose to or am I suppose to just line it up and crush it in? I haven't tried anything yet. I have a 1996 FXDWG (1340cc) with Python pipes. Not sure if they are, I don't see the name anywhere on them. I just recently bought it. Any info is appreciated. Thank you.
Old Jul 27, 2011 | 08:12 PM
buggy's Avatar
buggy
make sure you take old gasket out first. carefully install new one in then line up head pipe get bolts started and tighten evenly it will crush to make the seal .
Old Jul 27, 2011 | 09:03 PM
nevil's Avatar
nevil
The gasket does not slip over the pipe. The end of the pipe crushes the gasket into place. Do like buggy said, tighten evenly. Run it a few miles to get it hot, let it cool down and retighten. Use a torque wrench if you can, you don't want to snap off the stud.
And a good way to keep the nuts on is to double nut them.
Old Jul 27, 2011 | 10:08 PM
Joat Mon's Avatar
Joat Mon
Stage II
Default Great!
Thanks Buggy and Nevil. Your advice is much appreciated. I think I got it. Seems to run better now.
athome01
Exhaust System Topics
Oct 5, 2024 02:34 PM
Matthew Peoples
Shovelhead
Nov 26, 2017 02:54 PM
vduzin12
Oct 17, 2011 11:31 AM
deadreckoning
Shovelhead
Mar 26, 2009 02:35 PM
superglideharleyguy
Shovelhead
Aug 13, 2008 04:36 PM
