help installing D&D exhaust!
Old Oct 15, 2011 | 08:34 PM
vduzin12's Avatar
vduzin12
Default help installing D&D exhaust!
Trying to install my exhaust and having a hard time getting the header flange in the head. The OD of the header is 1.86" and the ID of the gasket is 1.62". I thought the gasket would at least fit over the header pipe. Is it suppose to crush the gasket? Or did they give me the wrong gasket? Their instructions say it is a "tight" fit but its physically impossible.
Old Oct 15, 2011 | 08:38 PM
dawg's Avatar
dawg
The exhaust gasket fits on the lip of the port in the head. It is not supposed to and will not fit over the pipe. The pipe pushes up against the gasket.
Old Oct 15, 2011 | 08:44 PM
Iceman24's Avatar
Iceman24
Yes, gasket is "crush type" and will form while you torque to spec...take a breather, have a cold one & go re-attack. Sometimes it's best to step away for a bit vs. throwing tools & swearing like a sailor...
Old Oct 15, 2011 | 08:45 PM
vduzin12's Avatar
vduzin12
understood but the factory header is tappered and the D&D is not so it won't even start go in. the only way would be to crush it. maybe I should try stretching the gasket a little?
Old Oct 15, 2011 | 09:07 PM
vduzin12's Avatar
vduzin12
its been a long day. already had a few
Old Oct 15, 2011 | 11:41 PM
Mike's Avatar
Mike
If the header flange has a squared off profile, you need the SE exhaust gaskets. If the header flange is somewhat tapered, you get the tapered, standard style gaskets. I use SE gaskets with my Rinehart headers.
Old Oct 16, 2011 | 01:38 AM
Harleydaddy's Avatar
Harleydaddy
Goose frabba!
Old Oct 16, 2011 | 08:01 AM
MassHD's Avatar
MassHD
I changed out the ones that D&D gave me for the SE ones. Much easier to work with and easier to install.
Old Oct 16, 2011 | 08:03 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
D&D's require the SE gaskets as stated above.
Drew
Old Oct 16, 2011 | 12:17 PM
firefighter156's Avatar
firefighter156
http://www.youtube.com/watch?v=zpXTz6is4aQ
+2 on the SE gasket.
