Broken exhaust bracket stud!
Old Aug 5, 2011 | 08:51 AM
Fixintu's Avatar
Fixintu
Originally Posted by p51bombay
EDM - simple answer is spark erosion
Cool, learned something new!
Old Aug 5, 2011 | 09:49 AM
Fixintu's Avatar
Fixintu
Update: just got off the phone with Harley Davidson. Bottom line, they will not cover the stud under warranty because an aftermarket exhaust was installed. I will most likely have the dealer replace it so that from that point on they will own it and the next time the stud breaks it will be on THEM.
Old Aug 5, 2011 | 10:13 AM
rcollinsdad's Avatar
rcollinsdad
Same thing happened on my buddies '09 but it was all 3 of the blot/studs that broke. we put his stock exhaust back on, took it to the dealer, and they covered it under warranty. Mechanic said it was a known problem with the Fat Bob's.
Old Aug 5, 2011 | 11:08 AM
Figgymo's Avatar
Figgymo
I had a similar thing happen to my WG. Except 2 of the mounting bolts broke off in the damn tranny case and the dealership couldn't get them out. HD had to replace the entire tranny case, it took a few weeks because they had stamp the VIN in a new case then ship out. All parts & labor covered under warranty, thank god.
Old Aug 5, 2011 | 11:10 AM
O-Town D's Avatar
O-Town D
"...we put his stock exhaust back on, took it to the dealer, and they covered it under warranty."
A very good reason to keep the OEM parts for a while...
Old Aug 17, 2011 | 04:09 PM
AFONE's Avatar
AFONE
Just happened to me yesterday. Have a Fat Cat that I was about to install. Checked the bike before riding to work in the morning and noticed that the top left stud into the transmission bracket had sheered off. Second time that's happened. A few months ago, the stud at the front head sheered off. Fortunately I there was enough left of it that I was able to get a grip on it an back it out. With the bracket stud, it sheerd off clean with the transmission. It's going to need to be tapped.
Old Aug 17, 2011 | 08:54 PM
Fixintu's Avatar
Fixintu
Damn broke *** studs shouldn't be breaking REGARDLESS of whether the exhaust has been changed or not. It's either a design defect or material defect. Apparently Harley doesn't want to come clean.
Old Aug 17, 2011 | 11:03 PM
calboy67's Avatar
calboy67
Check with another dealer. I had the same on my 2008 Fat Bob and had the case replaced also. It is covered under warranty. Known problem
Old Aug 19, 2011 | 06:54 PM
AFONE's Avatar
AFONE
I ended up fixing mine myself. Contacted the dealer and they said that since NY bike was 4 months out of warranty, they couldn't cover it. I just drilled a hole in the stud and used a tap to back it out.
Old Jul 1, 2013 | 07:05 PM
mattVA's Avatar
mattVA
Have those that have fixed this issue had further issues? Chalk it up to improper torque/loctite at factory. . .? I want to put my stock system back on but googling "fat bob exhaust bracket" is pretty scary. Seems every person's studs shear off. I'm out of warranty and can't find a replacement for the stud that's higher strength.
ABBob
Jul 1, 2013 01:38 PM
crackerbiker
Feb 20, 2012 05:40 PM
Inspector 12
Feb 25, 2011 10:01 PM
CVO ~ Senior Chief (Ret)
Exhaust System Topics
Sep 25, 2010 08:00 PM
columbia whaler
May 4, 2009 01:43 AM
