DOT 5 brake fluid
Old Aug 3, 2011 | 09:10 PM
Austin Dave's Avatar
Austin Dave
Default DOT 5 brake fluid
Dyna has 8200mi. I can't get in touch with PO and there is no maintenance record to go by. Spec is DOT5 brake fluid....new to me. Is this stuff like other brake fluid in that it 'attracts/holds' moisture? I have to assume the fluid is OE from '03 so, I want to completely replace it with a high-quality brand. Regular bleed process with my trusty Mity-Vac? Out with the old/in with the new. I've replaced all the other fluids, but forgot about the brake juice.
Old Aug 3, 2011 | 09:24 PM
08fxdf43202's Avatar
08fxdf43202
If the top of the master cylinder cover says DOT 5 then DO NOT use any thing other than DOT 5.
Old Aug 3, 2011 | 09:35 PM
DCLXVI's Avatar
DCLXVI
The DOT5 does not attract moisture like 3 or 4 but it is not compatible. It does have some advantages as well as disadvantages. It is silicone based instead of glycol based. That is why they are not compatible.
Old Aug 7, 2011 | 12:39 PM
Noteware's Avatar
Noteware
2nd Gear
Default dot 4 vs. dot 5 fluid
My 09 Super Glide calls for dot 4. HD has had an issue with this fluid since they starting using it around 04 - 05 (?). The master cyclinder gaskets can't stand up to it. Has anyone ever converted to dot 5 from the OE dot 4 ? I know it's not copmpatible to mix, but will a thorough flushing be ok?
I just replaced my master cylinder cover and gasket and there is much chatter on this forum from owners who have had recurring problems because of the dot 4.
Thanks for reading,
Mark
Old Aug 7, 2011 | 01:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Use what is label on the resevoir, if DOT it's not hydroscopic, you can bleed with traditional methods or Mighty Vac. It's purple when fresh and turns amber ove time.
Old Aug 7, 2011 | 01:47 PM
Austin Dave
My rear brake felt spongy so I checked the rear MC. About half-full. Could not find any sign of a leak? I emptied it and refilled it with new DOT5. Bled the air out until full steam of fluid. Rear brake works fine now. Bought 2 sets of pads when at the dealer buying the fluid.....just in case. OE pads on front and rear are fine. Both sets of pads cost just a few $$ short of $100. Will keep for time when needed. I doubt they will be less-expensive in the future.
Old Aug 7, 2011 | 02:25 PM
Harley Tim's Avatar
Harley Tim
Hello all,
Couldn't help but "chime in" on this one.
The answer is D, All of the above. However there are 2 more points not mentioned about the DOT 5. First, the good point, DOT 5 will not harm your paint , should you have a mishap like that. Second, the not so good point. DOT 5 has a lower boiling point. should be OK for the average rider but, if you do a lot of canyon carving or heavy duty stops and starts it could affect your bracking proficiency.
I converted my 06 Super glide to DOT 5 five yesrs ago and, have had no problems. Just be sure to evacuate the system of all the other completely, and go ask your local friendly HD parts guy or gal to sell you DOT 5 badged master cyclinder caps.
Best wishes...... Tim
Old Aug 7, 2011 | 03:50 PM
8541hog's Avatar
8541hog
Originally Posted by Harley Tim
Hello all,
You need to do a little more studying before you post comments like this, DOT 5 has a much higher boiling point than 3 or 4.
Taterdog
Mar 29, 2010 06:00 AM
128auto
Jul 16, 2009 12:44 PM
dobeman21
Sep 10, 2008 08:44 AM
anubisss
Mar 6, 2008 11:42 PM
darylnj
EVO
Feb 20, 2008 02:13 AM
