Progressive front spring ?
Old Aug 4, 2011 | 09:55 AM
DynaJ's Avatar
DynaJ
Default Progressive front spring ?
Ok I know that I can use the search function and I have but I dont have the time to scroll thru 100 threads sorry. So with that being said I ordered the lowering drop in kit for my 2009 super glide and my question is with the spacers they supply do they drop the front forks or do I have to cut them to lower it? I mean I know that pvc is so expensive and it would be hard for them to out several differnet options in the kit so you would not have to cut anything but oh well..I just dont want to cut something if I dont have to.
Old Aug 4, 2011 | 10:03 AM
dreamer65's Avatar
dreamer65
did you try the sreach options it works great
Old Aug 4, 2011 | 10:11 AM
DynaJ's Avatar
DynaJ
There is a search option??
Old Aug 4, 2011 | 04:08 PM
cjlandry's Avatar
cjlandry
From their catalog, it appears that the kit comes with everything you need and no special tools are required. Their website isn't so easy to navigate for such information.
Old Aug 5, 2011 | 02:43 AM
HemiOrange's Avatar
HemiOrange
The search option might work for you, but for some reason it has never worked for me. It directs me to posts that have nothing to do with any of the words that I entered.
The way I get around it is to Google it and look for HD Forums as the source. This saves me hours of searching.
I'm sure the lowering kit will have the spacers already sized for your application, but I've never bought a lowering kit, so don't know. On the other hand, if the thought of possibly having to cut spacers is beyond your level of comfort, then I don't know if you should be removing those fork caps to begin with.
If you do the job yourself, make sure you support that front end and take all the weight off of it when removing the caps. Make sure to loosen the top tube clamps first as they do create enough clamping force to prevent the caps from turning. It's also much better if you can raise and lower the front at will, I use a solid bike lift at the rear of the frame and a hydraulic jack at the front for quick fork compression and extension, but I'm sure that the instructions will cover anything that I have to offer.
Old Aug 6, 2011 | 11:02 AM
ggadwa's Avatar
ggadwa
Default Progressive Front Springs
Yes you have to cut the PVC Spacers. I just dropped my Front End one inch, and the kit includes simple instructions. Hack saw or cut off saw required. It is not a technical job. A vice comes in handy but not necessary. Very simple install. The nice part is you don't have to replace Fork Oil unless you want to go with new or stiffer oil.
GARY
Old Aug 6, 2011 | 12:38 PM
cjlandry's Avatar
cjlandry
Now you got me thinking about getting some Progressive replacement springs to go with my Ricor Intiminators. Will this money pit never end?!!!!????
Old Aug 6, 2011 | 11:43 PM
HemiOrange's Avatar
HemiOrange
Ricor does not recommend Progressive springs for their Intiminators. The valving in them isn't designed for progressively wound springs.
I've run into the same issues on the rear shock coil on KTM dirt racers with the direct link suspension, progressively wound springs throw off their valving.
It's best to stick with straight wound coil springs for custom engineered suspensions.
Old Aug 7, 2011 | 08:54 AM
cjlandry's Avatar
cjlandry
Thanks. I was wondering about that.
Old Aug 7, 2011 | 04:54 PM
DynaJ's Avatar
DynaJ
Ok I did the kit yesterday & yes I had to cut the spacers. Not a hard job but to get a clean 1 inch cut well that's another story, I really can't understand why they can't just throw 3 different sized spacers in there kits? But any how it's done I like the way it looks and rides..
cbennett1
Apr 15, 2018 10:44 AM
wingshootin1275
May 3, 2013 07:32 PM
Hferris
Feb 25, 2013 05:50 AM
jtmurph00
Sep 5, 2009 09:56 PM
skip3406
Jul 18, 2009 10:35 AM
