speedometer stops and starts...???
Old Aug 4, 2011 | 09:45 PM
fxdx-fly-by's Avatar
fxdx-fly-by
Default speedometer stops and starts...???
3 times now over the last few months my speedo will drop to zero and the digital odometer goes off, tach stays on (diff. gauges).. then about 2 seconds later it works again?? whats the deal?
Old Aug 5, 2011 | 01:16 PM
JerryDinMD's Avatar
JerryDinMD
I had a simular problem years back with a Sportster-it turned out to be the speed sensor that was on top of the motor-at least that's where it was on that Sportster-it cost like 30 bucks I think.
Old Aug 5, 2011 | 01:40 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
A few years ago my speedo acted strange also...I took out the speed sensor, cleanded it and problem was gone...
Old Aug 5, 2011 | 01:51 PM
BigAlsRK's Avatar
BigAlsRK
Replace the Speed Sensor....easy job....if you have to clean it you will be replacing it soon...might as well fix it now...IMHO
Old Aug 5, 2011 | 02:00 PM
FXD2003Rider
IMO no need to replace the speed sensor; cleaned mine four years and 35.000 km ago and it still works fine...
Old Aug 5, 2011 | 02:51 PM
BigAlsRK's Avatar
BigAlsRK
So you're saying that you have had to clean it more than once or twice?? IMHO I would just replace it....once.
Old Aug 5, 2011 | 06:06 PM
dubioproreo's Avatar
dubioproreo
Stage I
voltage regulator
I bought a new 2000 fatboy and this used to happen once in a while, but not often. I sold the bike with like 2500 miles and apparently it started doing it again. The guy who bought it took it in to a dealer. They said it had some crappy voltage regulator on it, not the regular stock one. I have no idea how it could have gotten swapped out. Once it was replaced it never happened again.
-K
thesportyone
Oct 16, 2013 01:33 AM
armymedic54
Mar 19, 2012 03:15 PM
petdoc94
May 11, 2008 10:05 AM
Zutroy
May 3, 2007 03:11 PM
emeraldbiker
Aug 14, 2006 10:32 AM
