Wheel Question
Old Aug 13, 2011 | 03:36 PM
johnsa28's Avatar
johnsa28
Default Wheel Question
Earlier this week I got back from a short ride to find out that 4 of the 5 bolts in my pulley on my rear wheel sheared off, so yesterday I took off the wheel to try to fix it but found a lot more damage than I expected. Not only did the bolts shear off in the hole my hub was bent on that side along with my pulley being cracked. So my question will Street Bob rims from 08+ work on my bike? Or did HD change them?
Old Aug 13, 2011 | 03:50 PM
thedonthere's Avatar
thedonthere
In 08 they changed from 1" axle to a 25mm axle so you would need to either change the bearings to 1" or get a 25mm axle
Old Aug 13, 2011 | 07:56 PM
AFMM3's Avatar
AFMM3
Here is your chance to put on a 16 inch and have wide white walls if that is your thing. You could try to find another hub and relace it. It is really not that hard to do and then have a local indie true it. It might be a lot less hassle to just get one from the forum classified or eBay. Also correct on the 08 and newer running 25mm bearings and axle. Just a few thoughts, hope one of them helps..............
Old Aug 14, 2011 | 01:50 AM
johnsa28's Avatar
johnsa28
thanks for the help guys and I just might go with your suggestion AFMM3
caulk04
Dec 8, 2016 06:49 PM
BluBeaSSt
Oct 21, 2014 03:46 AM
Baja38ss
Aug 20, 2014 07:25 PM
bigskyroadglide
Oct 24, 2011 02:51 PM
05dlx
Dec 25, 2009 08:52 PM
