Trans fluid = old milk?
Old Aug 14, 2011 | 10:04 AM
DCLXVI's Avatar
DCLXVI
I wouldn't use brake cleaner, just flush and replace and it will come out clean after one or two times.
Old Aug 14, 2011 | 10:18 AM
WS6 Formula's Avatar
WS6 Formula
I would check the condition of your transmission vent hose, it may be how the water is getting in.
Old Aug 14, 2011 | 11:06 AM
ynots's Avatar
ynots
I wouldnt risk using break cleaner, your seals may not like it. Refill, ride enough to get tranny up to operating temp. Then drain, refill and you should be good to go.
Old Aug 14, 2011 | 12:37 PM
SC-Longhair's Avatar
SC-Longhair
+1 Brake cleaner = bad idea.
Old Aug 14, 2011 | 01:23 PM
doorsidedown's Avatar
doorsidedown
AMSoil makes a flush for that. Basically, you drain a few ounces of oil, add the flush with the remaining oil, run it for 5-6 mins, drain it all out and then add your new oil. Voila.
Old Aug 14, 2011 | 01:29 PM
TUCCI's Avatar
TUCCI
Wow milky oil caused by water in the tranny...damn I wonder if it did any component damage? If it was mine I'd be freaked, keep that jewel indoors man, put cardboard under it and keep it in the living room holy cow!
Old Aug 14, 2011 | 02:05 PM
0lowrider1's Avatar
0lowrider1
Use a good gear oil in your trans ..I use amsoil 70-140 ...fully synth ...helps with moisture ...I would also check the vent hose ...that's really the only way water can get in your trans unless its comin in around dipstick.but if that's the case you should be leaking a little ..good luck
Old Aug 14, 2011 | 02:13 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Last year I had the same issue in my transmission.
After a three day trip into Germany at that time, I checked my oil cap several times during the 4 hours (highway) ride to get there from where I live (central part of the Netherlands): froth had gone!
This leads me to the conclusion this froth was caused by moisture from condensation combined with a (too) low engine temperature like some other members already suggested.
Like WS6 Formula said, check the vent hose, refresh the oil, let the engine get a nice temperature and your problem will be solved!
[/QUOTE]
Old Aug 14, 2011 | 05:16 PM
Cowpokey's Avatar
Cowpokey
Thanks for the advice all. I guess I'll try to just drain it, fill it run it, repeat. Hopefully that gets it taken care of. I'll take a look at the vent hose too.
Well, it would be wonderful to have that option. They don't carry squat over here. I had one option for engine oil this time around, so it got Valvoline dino...
Old Aug 14, 2011 | 05:22 PM
Cowpokey's Avatar
Cowpokey
Unhappy
Interesting. If getting it up to temp could fix it (help), there must be a ton of water in mine, I've been doing some long rides.
