Looking for some cable info
Old Aug 16, 2011 | 10:59 AM
clayman's Avatar
clayman
Default Looking for some cable info
Im putting 16 inch apes on my 2010 wide glide, from what i measure it looks my cables will need to be +13. I dont want to have alot of excess so any info on what others have used would be really helpful before i order. Thanks
Old Aug 16, 2011 | 08:36 PM
SC-Longhair's Avatar
SC-Longhair
No more than +8. +6 sounds closer to the actual.
Old Aug 17, 2011 | 08:15 AM
ucommbxny's Avatar
ucommbxny
Me and my son are installing a set of santee bonanza II 13" bars on his 2007 FXD, we used 48" brake line, 60" throttle cables, and +8 clutch cable. Since you are 3" taller then the bars we are installing these measurements should work. 50" brake line, 62" throttle cables, +8 clutch cable. Most important ask the shop if you can exchange cables if you have to, we had to exchange 2. Had to add this update the plus 8" clutch cable on the 13" is a little to long after we rerouted the cable to the inside of the bars, the rest of the cables are fine. Good luck.
daisy cutter
Harley-Davidson Street
Dec 11, 2017 03:51 AM
SwiftyBKells
Dec 3, 2013 07:38 AM
fourH-Ds
Aug 21, 2012 08:49 AM
mtn-glide
Aug 22, 2010 10:55 AM
rhoppe
Sep 13, 2008 10:00 AM
