How do the bars not slap the tank on that fat bob with the 2.5 lift? It has to severely impact your turning capabilities.
Check out the risers. That bike has no clearance problems.
Don't reckon anyone should ever install a tank lift where the bars can't go from lock to lock. Only a matter of time before the tank gets a dent.
It is really easy to check what your bike will look like with different height tank lifts (and to make sure there are no clearance issues).
1. With bike on kickstand, take the bolt out of the front of your tank.
2. Loosen (do not remove) the bolt at the rear of your tank.
3. Use a towel to put between the tank and backbone, step back and see how it looks...once you get the height you like, measure center of bolt hole on frame to center of bolt hole in tank ear.
Also, once you have it at the height you like, turn your handlebars all the way to the left and right (carefully) to check for any clearance issues.
It looks like the 3" does raise it up a bit too much. It kind of adds an extra line under the tank that doesn't seem to look right. I guess a 2" will have to do but the 3" does give the upper part of the tank a better line with the seat. Thanks for the pics.
