anyone ever seen this?? <pic>
Old Sep 4, 2011 | 12:30 PM
escherWG's Avatar
escherWG
Default anyone ever seen this?? <pic>
i used a couple of 1" steel washers for the spacers on between the hub and calliper, and after a short test ride (less than 2 miles) i notice the paint on the caliper was bubbling and the washers seem to be discolored.
where is the heat coming from?
i'm thinking the axle might be too tight? and the washers are spinning?? i don't know, any thought??
Old Sep 4, 2011 | 12:34 PM
Smokey Burnouts's Avatar
Smokey Burnouts
Think ur right.... something is rubbing and creating alot of heat. my guess would be loose one of the washers or maybe the washers are too big in diameter and is touching something it shouldn't.
Old Sep 4, 2011 | 12:49 PM
OldMike's Avatar
OldMike
You have a problem. My bike had a spacer that sits against the inner race of the bearing allowing the outer race to spin freely. I've attached a picture. Your bearing is now suspect if it took a lot of heat, and it looks like it did.
Good luck,
Mike
Old Sep 4, 2011 | 12:51 PM
blueangel73's Avatar
blueangel73
Take a maker and make a line across washers and the caliper and then go for a ride. If the lines move then chances are the washers are to large and the inside washers is rotating with the outside of the bearing housing while outside washer is trying to rotate with the inside washer and stay still with the caliper housing. All that friction is more than likely causing your problem. A washer larger then you inside (smaller ring on axle bearing, the race Mike is refering to) bearing ring, but smaller then the larger outside ring (bearing ring pressed into the hub) would work.
If the lines don't move or move slightly, then your issue could be the washers rubbing the axle. This is very bad because not only is it causing the problem you are already seeing, but chances are that the washers are also damaging your axle from the rubbing.
Hope this helps! Good luck, let us know what you find out.
Old Sep 4, 2011 | 12:53 PM
baxter's Avatar
baxter
Did you add the washers due to a modification or were they there from the factory?
frostvair's Avatar
frostvair
Stage III
You have captured the inner and outer races of the bearing making the washers spin against the caliper bracket creating friction.
Old Sep 4, 2011 | 02:35 PM
superrooster2003's Avatar
superrooster2003
the washers are touching the outer race of the bearings and are getting hot u must of lost the spacer the washers are too big
Old Sep 4, 2011 | 04:05 PM
mang0's Avatar
mang0
what happened to the original spacer?
Old Sep 4, 2011 | 04:46 PM
gplarryv's Avatar
gplarryv
Thats what I'm saying.
Old Sep 4, 2011 | 04:50 PM
Stiggy's Avatar
Stiggy
That's it in a nutshell. We can't even see your bearing behind the washers!
