Bike Chirping
Old Sep 7, 2011 | 07:23 PM
clayman's Avatar
clayman
Id think if it was the statop that i would hear it closer to the source. Did you hear noise through the exhaust
Old Sep 7, 2011 | 07:28 PM
Fatboy Brian's Avatar
Fatboy Brian
What kind of air cleaner do you have? My heavy breather made chirping sounds on my 08 Fatboy.
Old Sep 7, 2011 | 08:00 PM
Reaper_ggy's Avatar
Reaper_ggy
Strut cover.
Old Sep 7, 2011 | 08:04 PM
Reaper_ggy's Avatar
Reaper_ggy
When I removed the sissy bar I didnt put any spacers ... It took a while to squeek but when it did it droved me insane I dissambled almost everything on the bike ... ex ... running without exhaust. Finally founded out with a friend that it was the damn strut cover scraping against the upper shock eye.
Old Sep 7, 2011 | 08:35 PM
clayman's Avatar
clayman
I had the heavy breather on but took it off and tries a sceamin eagle i had layin arround. Thanks reaper i will have a look at the struts. Did your noise sound like it was coming from the exhaust?
Old Sep 8, 2011 | 05:50 AM
golfmajic's Avatar
golfmajic
From: Ottawa, Canada, summer, Daytona Beach Florida, winter
Found mine to be the rear exhaust mount at the engine on my Rineharts, the bolt was loose, only made the noise from time to time, drove me nuts.
Old Sep 8, 2011 | 08:29 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Chirp = belt tension (usually too loose)
Old Sep 8, 2011 | 08:51 AM
danrad55's Avatar
danrad55
Just finished fixing a "chirp" that was driving me crazy. I thought it was coming from my exhaust. Started in Sturgis when I was riding around without any baggage. Turned out that the screws holding my backrest were loose and one was missing. When loaded with luggage, no issue. Tightened them up and replaced the one that was missing and the problem was solved. Definitely a metal-on-metal issue for me.
Old Sep 8, 2011 | 04:24 PM
clayman's Avatar
clayman
Ive tightend everything i can think or that has been suggested but its still there. I dont see how it could be the belt, while the bike is idling i push the belt with my foot and there is no change in the noise. Ahh well the hunt goes on!!! getting sick of it though..
Thanks for all the suggestions
Old Sep 13, 2011 | 06:51 PM
Reaper_ggy's Avatar
Reaper_ggy
Yes I was 100 % sure it was the exhaust I even took it off because it drove me insane. I'm telling you either put a spacer between the strut cover and youre fender or remove the strut cover.
Just remove it... that way you'll know for sure.
