Should I switch to poly bushings?
Old Jul 6, 2012 | 05:26 AM
kmontague's Avatar
kmontague
i have poly bushings. and iso grips. dont really notice any more vibs. but the iso grips are very much nicer than stock grips
Old Jul 6, 2012 | 07:02 AM
SPECIAL ED's Avatar
SPECIAL ED
I've always had a problem with my hands going numb, I doubt it's my poly riser bushings but I may go back to rubber just to see if it helps it's a pretty easy swap.I think in my case it's just poor circulation my hands go numb on my cafe racer clubmans and on my Harley with the Switchback bars.
Old Jul 6, 2012 | 04:02 PM
retxpres's Avatar
retxpres
Originally Posted by retxpres
While having my lowers and trees powder coated I had the poly bushings installed. I have really noticed a huge increase in vibs on my stock 2011 Wide Glide Handel Bars and Risers. Now I am thinking of just going back to the stock bushings. I really dis-like the way it is now. Has anyone else gone back, like I am planning? And did it make the difference that I am looking for...
I went back to rubber bushings. Much better... I can use my mirrors now. The handle bar vibes are gone. My opinion is that with low bars the rubber bushings are better. They absorb the vibes. Probably with apes you would be better off with the poly because the rubber bushings would flex with added leverage of the taller bars...
Old Jul 6, 2012 | 10:39 PM
Billyjo88's Avatar
Billyjo88
Apes need poly bushings...
Old Jul 7, 2012 | 07:17 AM
perryross's Avatar
perryross
I've used poly bushings on all my bikes, no problems.
Of course all of them did have taller bars.
http://s1125.photobucket.com/albums/...h/6%2028%2012/
Old Aug 6, 2012 | 09:58 AM
Elemental13's Avatar
Elemental13
i just installed new poly bushings this weekend because my big issue is i did not like the bars moving when i pushed the bike or pulled it i just didnt feel comfortable with the movement and i went to the polys did not notice much as in vibrations but i did notice the mirrors were hard to see out of now so i think im going to find a way to rubber mount those
Old Aug 6, 2012 | 10:47 AM
rharris27's Avatar
rharris27
or you could do what I did when I installed my t-bars... just tighten the crap out of the stock rubber bushings. They'll become real solid like after that. Mine have no play in them at all.
Old Aug 6, 2012 | 12:07 PM
Elemental13
the only issue with that is you run the risk of pulling the threads on the risers or cracking the the bars
Runcy12
11
Sep 4, 2018 11:54 AM
mikejorg
Apr 21, 2017 12:18 PM
RKCruzin'
Nov 16, 2015 03:12 PM
parkashard
Sep 17, 2011 06:21 AM
TheBreeze521
Dec 27, 2008 07:54 AM
