Street Bob Wheels
Old Sep 19, 2011 | 04:51 PM
crimson13's Avatar
crimson13
Default Street Bob Wheels
I am new to the forum and I have a question already, I am pretty sure this has been answered but I am at work and dont have time to research anyway I a 2011 street Bob and wanted to know if cast wheels from a 2000 dyna fxdl will fit on my bike? Any help will be apreciated,Thanks
Chris
Old Sep 19, 2011 | 05:03 PM
Robbie13's Avatar
Robbie13
LOSER
Hey Chris. Welcome to the forum. I got rims of a low rider on my bike. Look at my pics and see if they are the same ones you are talking about. I think mine came off a 06. I had to have spacers put on to make mine fit.
Old Sep 19, 2011 | 05:36 PM
Shaved Ice's Avatar
Shaved Ice
The axles changes sizes somewhere in there. Someone smarter than me on this will be by momentarly.
Robbie13's Avatar
Robbie13
LOSER
Ok. My bad. Now I remember. The main difference on mine was the width of the wheel bearings on the two different rims. I had to have spacers added to make up the difference.
Old Sep 19, 2011 | 07:38 PM
crimson13's Avatar
crimson13
cool thanks i found some on ebay for a 150.0 bucks
Old Sep 19, 2011 | 07:45 PM
ryderbiker's Avatar
ryderbiker
Your street bob has 1" axles. Prior to 2006 they were smaller. Not sure if you can change the bearing to fit but they aren't a direct bolt on.
Old Sep 19, 2011 | 07:47 PM
SuperFastGlide's Avatar
SuperFastGlide
06-07 are 1 inch 08 and above are 25mm axles
Old Sep 19, 2011 | 07:51 PM
crimson13's Avatar
crimson13
Here is the ebay link of what I am looking at if this helps
http://cgi.ebay.com/ebaymotors/ws/eB...84.m1423.l2648
Old Sep 19, 2011 | 08:43 PM
SuperFastGlide
that wheel wont work,,, for the easiest swap you need 08 and up superglide or low rider mags
Old Sep 20, 2011 | 05:53 AM
AFMM3's Avatar
AFMM3
2008 and newer have 25mm bearings. You have 25mm axles. The 25mm bearings are not as thick as the previous 1 inch bearings. They utilize an additional spacer inside the hub to make up the difference. 25mm bearing will fit into the wheels you want. If you find someone competant, they could remove your bearings and install them in your new wheels.
Helpful Hint: purchase new bolts for your rear wheel pulley as the manual states. Use the proper Loc-tite and a good torque wrench. Many folks have found their bolts have loosened up and destroyed the wheel.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
