Thinking about the approaching winter.
Old Sep 21, 2011 | 09:57 AM
USMAMule's Avatar
USMAMule
Default Thinking about the approaching winter.
The winter is fast approaching and a middle aged guy's mind turns to winter bike projects. I have decided it is time to start doing power and handling upgrades. I am pretty sure Progressive shocks and drop ins are in store. But I am also thinking of power upgrades. Not being a mechanic, and reading the forums for a couple years now I know there are a few things I can do short of a new engine. I am pretty mechanical and have a decent set of tools from torque wrenches to a full complement of metric and standard sockets and Torx and hex wrenches and a lift and am thinking I want to do the work myself if at all possible. question for the more experienced wrenches out there.
So I know Cams are a start - are new lifters and springs needed? If I switch cams do I need to do a fuel management system? I have currently have the stage one (w/ V&H BR 2-2 and Screamin' Eagle Ventilater) done from the dealer when the bike was new. Also thinking or replacing the Ventilator with an S&S Teardrop, as the back end hits my knee.
And advice, suggestions, guidance from you guys would be greatly appreciated.
Thanks In Advance,
USMAMule
Old Sep 22, 2011 | 04:41 AM
HemiOrange's Avatar
HemiOrange
What year bike are you intending to upgrade? FI or carb? What is your budget? Can you spend $1000 on front and rear suspension? How much HP and TQ do you want?
Old Sep 22, 2011 | 07:43 AM
USMAMule's Avatar
USMAMule
It is a 2010 Wide Glide. Sorry about not being specific. LOL... I sometimes forget that more than a few folks have more than one bike. And yeah I was thinking a budget of about $2000 for parts this winter - including suspension. Wanting to drop it a bit so I think it is common sense to drop the front and back the same 1" to keep handling steady. But maybe that isn't the case?
So I was thinking a 1" drop through shorter than OEM shocks and the 1" inch lowering drop ins for the forks from Progressive. Living in rural NJ I get a lot of twisties on daily rides to work, and I like to have fun.
As far as performance - not really targeting a HP/Torque goal. I'd just like a wider power band for said twisties and passing tourists in cages that seem to think teh whole world is on vacation same as them and have no where to go.
Thanks,
USMAMule
Old Sep 22, 2011 | 07:59 AM
CobraEd's Avatar
CobraEd
time to put the snow tires on the bike.
Old Sep 22, 2011 | 08:01 AM
USMAMule's Avatar
USMAMule
No offense but been there, done that, dumped the bike and will never do it again.
USMAMule
Old Sep 22, 2011 | 08:04 PM
USMAMule's Avatar
USMAMule
bump Any help guys? Suggestions? Experiences?
USMAMule
Old Sep 22, 2011 | 08:30 PM
missedem's Avatar
missedem
You might look into the fuelmoto 107 kit. looks like a great setup.
Old Sep 22, 2011 | 08:52 PM
nevil's Avatar
nevil
I can't speak from experience on motor mods, had installed a stage 1 with TMax on my 07 Street Bob about 3 years ago and am very satisfied with the power increase.
Last year I lowered the bike and found that it limited the amount of fun I could have in the twisties, which is most of the riding I do. Too much grinding of parts for my liking, and a harsher ride.
So I went the other way and put on 1/2" longer Ohlins on the back. No more scraping and way more stable cornering and comfort. The front end has Progressive springs and it helped, that will be the next area I look at. For great suspension advice, look up Howard at motorcyclemetal.com, a sponsor here.
Old Sep 22, 2011 | 09:29 PM
annapolisfatbob's Avatar
annapolisfatbob
have never done engine work to a motorcycle but i have to my gto so i would guess you would need upgraded springs/lifters/hardened pushrods. proly depends on the cam grind as well. with a cam you should definitely get a tune or pcv and do it yourself. good luck with the winter project.
Old Sep 22, 2011 | 09:52 PM
HemiOrange's Avatar
HemiOrange
That is the place and kit that seems to be the best bang for the buck. However, it will more than use up his budgeted $2k.
