Help with gps install
Old Sep 23, 2011 | 07:32 PM
Drdriller's Avatar
Drdriller
Default Help with gps install
I am putting on a gps on my 2011 fat bob. Any reason why I can't splice into the positive and negative headlight wires for the gps power?
Old Sep 23, 2011 | 07:53 PM
PigInaBlanket's Avatar
PigInaBlanket
It's your bike, do whatever the hell you want. I ran my wire down to the accessory fuse but the headlight would probably be just as good and maybe easier.
Old Sep 23, 2011 | 08:21 PM
ynots's Avatar
ynots
like mentioned above, but why not go to the accessory fuse?
Old Sep 23, 2011 | 09:25 PM
dyna rider's Avatar
dyna rider
Default Wiring
You just have to be sure the headlight wires you tap into can carry the load of the light plus the GPS. The accessory connector under the seat is switched and has no load on it...
Old Sep 23, 2011 | 10:36 PM
donzolio's Avatar
donzolio
i ran an 12v acc outlet to my accessory fuse and ran wire under gas tank and zip tied to harness just behind triple tree. used a ram mount and regular car plug for my tomtom go720. can also charge cell phone and ipods while on road. 09 FXDC
Old Sep 23, 2011 | 10:55 PM
jwright302's Avatar
jwright302
I wouldnt think that gps would draw much power at all. I'd consider making the quick and easy connection BUT then again if something goes wrong on the road you could be without a headlight. Been without a headlight once and it wasn't fun. Haha.
Old Sep 24, 2011 | 06:16 AM
8541hog's Avatar
8541hog
Considering the available accessory power both under the seat and at the neck into the bars, I would not run it off of a wire that is dedicated to something as important as your headlight. As mentioned it really sucks when it goes out at night.
Old Sep 24, 2011 | 07:57 AM
Drdriller's Avatar
Drdriller
Good advice, I just have to find the accessory fuse. Anyone have a picture or explanation for a dummy like me?
Old Sep 24, 2011 | 10:43 AM
PigInaBlanket
Pull the cover off your fuse box and look in your owners manual.
Old Sep 24, 2011 | 10:49 AM
NDBadlands4-2's Avatar
NDBadlands4-2
What type of GPS are you installing?
