oil question..
Old Sep 28, 2011 | 05:55 AM
cam-921's Avatar
cam-921
Default oil question..
First off, I have tried the search but way too many threads and none with the answer I'm looking for. The wide glide is almost at 1k. I want to do this and all services myself. The manual says 20w50 for engine and chaincase oil for tranny and primary but I have seen many on this forum using the same in " all 3 holes". On the HD website it says syn3 is good for all 3 but what about dino oil. Can I put a dino 20w50 in all 3? It would just seem more convenient to buy a case or 2 of one oil... also the manual says you have to replace gasket and o-rings every change...is this really needed?
Old Sep 28, 2011 | 06:03 AM
LarryLives's Avatar
LarryLives
The way I see it is:
HD uses 20/50 in the engine and primary, so do I!
They use Gear oil in the trans, So do I!
I'll bet you can use corn oil in the trans, but would you??
Just stick to what they use, its not like its a added expense, its just as easy to use gear oil. I use all Amsoil and love it.
Old Sep 28, 2011 | 06:12 AM
OldMike's Avatar
OldMike
What oil should I use?
Old Sep 28, 2011 | 06:33 AM
11bDad's Avatar
11bDad
Use this in all 3 holes. It even has the HD #1 on the container.
Old Sep 28, 2011 | 06:58 AM
YeOldeStonecat's Avatar
YeOldeStonecat
I drink beer and **** in the primary....the primary doesn't care what's in there (or not).
My opinion.....try several different ones and see which one you and your bike seem to like the most. What makes it sound best to you? (as far as primary/tranny sounds). What makes it shift smoothest and best for you?
People ride differently, live in different temp and altitude areas, their bikes broke in differently, a certain oil may seem better for one person, and that same oil may not seem as good as another brand for a second person.
You're not talking about a lot of quarts of oil in your bike....so it's not expensive to try different oils and see which one you like the best.
I use synthetic for V-Twins in all 3 holes. Usually Castrol, or Mobile. Whatever is on sale or priced OK at the local auto supply store I happen to drive by at the time I feel like getting oil...be it Bennnys or AutoZone or Pep or whatever...s'long as it ain't the stealership.
I would not however, use regular dino oil in the tranny..if I wasn't going to use Synch rated for all 3 V-Twin holes, I'd use some gear oil.
Old Sep 28, 2011 | 07:06 AM
skidder's Avatar
skidder
I use Redline 20w50 in the motor.
Redline Primary fluid in the primary.
Belray bigtwin tranny oil in the gearbox.
Old Sep 28, 2011 | 07:07 AM
sm0kediver's Avatar
sm0kediver
+1 on that. I now use this stuff instead of Lemon Pledge to clean my bike as well. It's nice just having one container on my work bench. Less confusing.
Old Sep 28, 2011 | 08:38 AM
cam-921's Avatar
cam-921
I would not however, use regular dino oil in the tranny..if I wasn't going to use Synch rated for all 3 V-Twin holes, I'd use some gear oil.[/QUOTE
That's what I was looking for. I have a case already of castrol v twin for my other bikes but not synthetic...I really don't want to give the stealership another dollar if I can help it but i may have to for filter Derby cover gasket...
Old Sep 28, 2011 | 08:51 AM
8541hog's Avatar
8541hog
If we all felt that way where would the dealers be when we really needed them?
I always use gear oil in the trans, it's a gear box not a motor.
Old Sep 28, 2011 | 09:57 AM
YeOldeStonecat
No need to replace the derby coffee coaster each time you pull the cover...long as you're not brutal with it working with the torx screws...it should easily survive a dozen removals.
