Drag Trees on SB Help
Old Sep 29, 2011 | 06:26 AM
HD Bobber's Avatar
HD Bobber
Yah I will go w/ an an 06 top tree then since its 49mm.
U guys know if it looks the same as the bottom tree or diff. so I heave to get both to match?
Old Sep 29, 2011 | 06:36 AM
HD Bobber's Avatar
HD Bobber
Originally Posted by n0code
Joker machine has got some new dyna trees.
http://www.jokermachine.com/itemstre...&Placeholder=0
Hess guys make some great parts!
Those are nice. Im gonna have to find out how much they go for.
LONER INDUSTRIES http://lonerindustries.com/Products.aspx
looks like a spot on replacement for the stock for only $175!!!!!
Old Sep 29, 2011 | 02:03 PM
stev0n's Avatar
stev0n
the Loner tree looks exactly like my OEM tree.
Old Sep 29, 2011 | 03:01 PM
stewbeezer's Avatar
stewbeezer
Originally Posted by stev0n
06+ is 49mm. so fxdb, fxd, fxdc, or low rider will work
I don't think a Low Rider top tree will work with the his stock lower tree because Low Riders have rake in their trees.
Old Sep 29, 2011 | 08:33 PM
Bo_Jangles's Avatar
Bo_Jangles
Fxdl won't work, they have the built in 3 degree rake in the tree but like everyone else has said 06-07 SB and 06 up FXD and FXDC. Just be sure to check part numbers I almost bit off on a low rider off eBay.
Old Sep 29, 2011 | 10:00 PM
HD Bobber's Avatar
HD Bobber
I just bought the loner industries tree.
Old Sep 29, 2011 | 11:08 PM
itsteeravfool's Avatar
itsteeravfool
Just for clarification guys, the 2006-2007 SB upper tree will not fit on the 08 and later street bob. I bought one, powder coated it and tried to put it on, it fits but the fork tubes to not line up, its about an inch too far back when compared to the bottom. Anyone planning on doing this should buy an 08 and later superglide upper tree.
EDIT: I believe they may have changed the rake slightly when the went to the integrated risers on the upper tree in 2008. Just because they're 49mm doesn't mean ****, this is coming from someone who learned this a week ago and then had to by a 2011 superglide top tree...
Old Sep 30, 2011 | 07:30 AM
SC-Longhair's Avatar
SC-Longhair
I just googled every year FXDB from '06 to '11. They all have 0* rake in the trees, 29* in the neck.
Do you have photos of your stock tree vs the replacement you purchased? Would love to see.
Old Sep 30, 2011 | 12:44 PM
Grundlepunch's Avatar
Grundlepunch
post up when you get it installed. thinking about going this rout as well
Old Sep 30, 2011 | 12:55 PM
HD Bobber's Avatar
HD Bobber
Im redoing my bike quit a bit so once everything is in will post it up.
Thanks for all the advice and help guys.
