Inverted Front End
Old Oct 2, 2011 | 01:25 PM
BIGDADI's Avatar
BIGDADI
Question Inverted Front End
Looking to put an Inverted Front End on the Street Bob this winter, Hoping to find one with a mix of black and chrome. But I know how important a good front end is, I don't want to get screwed, so if you guys could post pics and recommendations that would be great!
Old Oct 2, 2011 | 02:06 PM
thedonthere's Avatar
thedonthere
07-08 SE Dyna.....direct bolt on.........uses wide glide wheel
Old Oct 2, 2011 | 09:54 PM
Bo_Jangles's Avatar
Bo_Jangles
storz performance... or motorcycle metal
Old Oct 3, 2011 | 05:47 AM
FastHarley's Avatar
FastHarley
Former Sponsor
If you are considering a new fork, what are your reasons?
  • If you are doing it for looks only there are some very inexpensive e-Bay complete units out there. They are chrome, large, heavy and offer no riding improvement except looks.
  • If you are looking for ride improvement than you must do your homework more than asking for opinions here.
  • It is the internals that are important and not the color.
    • It is adjustable ie: compression, rebound, and spring pre-load?
    • How large are the cartridges.
    • How does it work ie: bushings encapsulated into the slider and the fork tube slides in them or does the bottom of the slider have a bushing and the top (inner) bushing is encapsulated on the fork tube and slides onto the aluminum slider?
    • What kind of calipers will fit? What type of caliper mounting system on the axle clamps does it have: ie: radial or side mount?
    • Is it easily rebuild-able and can you get parts from the vendor?
    • Is it the right length?
I hope I have helped you decide to get what is right for you as far as research goes.
crtman21
Aug 23, 2016 08:12 AM
joneill
Aug 14, 2013 12:04 PM
milesvdustin
Apr 10, 2013 07:23 PM
JDixon
Mar 12, 2008 07:34 PM
ad2
Nov 4, 2005 10:48 AM
