peg shims!
Old Oct 2, 2011 | 04:22 PM
VirtualNorm's Avatar
VirtualNorm
Default peg shims!
Need a set, where are they at other than a dealer? ACE hardware cary some thing like this or mail order? Thx
Old Oct 2, 2011 | 04:52 PM
dynabobster's Avatar
dynabobster
Are you talking about the square shaped spring washers? If so, I would recommend replacing them with the OEM ones, but you might be able to go with a few round waved spring washers and I know my ACE carries them. They are there to tension the peg so it does not flop down so you need a washer(s) with enough tension and not so many that you can't properly tighten the bolt, etc.
Old Oct 2, 2011 | 06:29 PM
Ganooch's Avatar
Ganooch
I threw mine out. Replaced the passenger pegs with OEM and they wouldn't fit with the washers. Installed without and the pegs flopped around like crazy. Over-torqued the bolts and now they stay put. Gotta pull hard to move them up and down, but it works. Wish you asked a couple of days earlier, I would have sent you mine (even though they were rusted to hell).
Old Oct 2, 2011 | 08:46 PM
HemiOrange's Avatar
HemiOrange
I've had to tap a few spring washers into place before, then use a long punch to get them aligned.
Old Oct 2, 2011 | 09:55 PM
VirtualNorm
Well crap, a bit of rust never hurt I am always a day late. I will run down to the dealership and pay the price for a set, i was just hoping that there was a hardware store alternative. Thanks for the input guys. Much appreciated.
Old Oct 2, 2011 | 10:31 PM
Ganooch's Avatar
Ganooch
Man, these weren't going in. Hammer, mallet, pliers, I tried it all.
Old Oct 3, 2011 | 07:41 AM
reclaimer53's Avatar
reclaimer53
Every 2,000 miles I have to take my rear passenger pegs off and put in a little more bend to put more friction on the rear pegs to keep them from falling down. I never thought about banging them in or forcing them but I guess that would work too.
Old Oct 3, 2011 | 08:04 AM
Ganooch's Avatar
Ganooch
May not be the best advice, but that bolt is pretty big. Over-torquing them (slightly) should close the receiver up enough to keep them in place.
Old Oct 6, 2011 | 10:16 AM
tnkrizzo's Avatar
tnkrizzo
I made mine out of 6061 T6 aluminum on my lathe and punched it through the center. I torqued the hel out of the bolts and all was well. It works great and does not bind. Without making new centers, it would have been terrible with washers/shims.
nitrohound
General Topics/Tech Tips
Apr 25, 2026 06:56 PM
PPBART
Jan 1, 2010 06:56 PM
KRS
Mar 20, 2009 02:33 AM
HaloFan
Aug 27, 2008 06:13 PM
twoseas
Apr 10, 2006 12:48 AM
