Rear turn signal relocation kit??
Old Oct 7, 2011 | 07:44 PM
2_slow_5.0's Avatar
2_slow_5.0
Default Rear turn signal relocation kit??
http://www.customdynamics.com/v-rod_...ccessories.htm
Is there something like this that will work with the dyna's?? Or will this one work? Really liking the idea of it and once I cut down the fender I think it will set the look of the back!
Old Oct 7, 2011 | 08:52 PM
SC-Longhair's Avatar
SC-Longhair
I'm sure you could make a small bracket that would fit between the top shock mount and the strut cover. Bullet lights aren't expensive either.
OR
You could call that company anf find out what the I.D. (inside diameter) of the mounting holes are. Undo one of your top shock mounts to see if that bolt will fit.
$220 seems awfully expensive for that you want to do though.
Old Oct 8, 2011 | 07:41 AM
Deadwood's Avatar
Deadwood
Similar but different set up I did to my bike however instead of at the bottom these brackets are meant to be at the top end of the shock mount.
https://www.hdforums.com/forum/8537384-post1733.html
Old Oct 8, 2011 | 08:57 AM
2_slow_5.0's Avatar
2_slow_5.0
Yea I think I am going to make something like this and mount mine up top. Just bought a 180mm tire and want to move my tail lights and plate off the fender so there are no issues with the wiring.
Old Oct 8, 2011 | 04:40 PM
Deadwood's Avatar
Deadwood
Only issue I foresee is if you use saddle bags, turn signals may be hidden otherwise those brackets in the link were only $20. They fit perfect over the shock bolts. Post some pics when your done.
camden
Oct 14, 2014 05:25 PM
buell12
Apr 27, 2013 03:28 AM
stickystuff
Jun 27, 2012 09:50 AM
DGlide04
Sep 23, 2010 05:12 PM
rockon
Oct 20, 2008 08:07 PM
