Bike won't start - fuel injection problem?
Old May 29, 2013 | 10:28 PM
'11 SGC rootbeer's Avatar
'11 SGC rootbeer
Just read this. I was gettin pissed off. No fuel pump, no start......This bike has 10,000kms and it won't start? Started doing it randomly last couple of rides but always started after a few tries. then this last time wouldn't start. Ir is In the garage at least.
Took relays out, both had a bit of rusty residue on them. Gave them a tap on the floor and blew on them....Put them back in and..... pump, fire, road test.
Yesssss!!!!!!!!! Thank god it isn't a major and that people have posted and shared their experience. Thank you, thank you, thank you.
Old Feb 18, 2014 | 04:38 PM
rshaw25's Avatar
rshaw25
Stage III
You guys da best. Smacking the relays around worked. I'll have to get new ones but happy that's it
Old Dec 26, 2016 | 06:32 PM
Peter Ertel's Avatar
Peter Ertel
6th Gear
My 2008 883 won't start either, but I do hear the fuel pump run to pressure.I think it's electrical because it's full of gas, starts (but doesn't continue) when squrited, and happened all of a sudden.Fues and relay are OK.
Old Dec 26, 2016 | 06:54 PM
1957buick's Avatar
1957buick
look in the tank when pump comes on see if there is fuel squirting inside the tank if so you have a hole in fuel line it may cough but not run , my 08 ultra did this to me
Old Dec 26, 2016 | 07:09 PM
bic's Avatar
bic
6th Gear
What do you mean when you say starts (but doesn't continue). Do you mean that it cranks but does not start.
Old Dec 26, 2016 | 08:33 PM
Peter Ertel
6th Gear
Runs until the gas squirted in the throttle body is used up.
Old Dec 26, 2016 | 08:47 PM
bic's Avatar
bic
6th Gear
do you have any codes
Old Dec 27, 2016 | 10:11 AM
Peter Ertel
6th Gear
Yes, "PO 152"
Old Dec 27, 2016 | 12:24 PM
bic's Avatar
bic
6th Gear
P0152 Rear O2
sensor high (rich)
ma
Old Jun 18, 2017 | 10:53 AM
Robby999us's Avatar
Robby999us
5th Gear
Originally Posted by Crash Davis
I have a 2007 Street Bob with ~sigh~ only 7500 miles. Last weekend the weather was beautiful and I was going to get some miles on the scoot, but it wouldn't start. When I turn on the ignition and flip the switch to run, I don't hear the usual whine of the fuel pump.
The usual lights come on and the bike turns over strong, but won't start. I figure it's because it is not getting any fuel. I'm really hoping there is an easy solution, and I don't have to replace the pump. I checked my fuses and they all look fine. I replaced the fuse for the EFI with the spare just to be sure, but it didn't make a difference. (And yes, I have the start switch in the 'run' position!)
I searched the forums, figuring someone else had to have the same problem but no luck. Is there anything else I should be checking, or do I have to suck it up and get my bike to the dealer?
Hello Crash Davis, have you fixed the problem with your fuel system ? I have exactly the same problem with my 2003 Heritage softail. I am also missing the wining noice from the fuel pump and she won't start. Would be great to hear from you how things are going.
Best Robby
