bundy bruiser V&H dealers but apparently the o2 plugs wont fit Thats not a problem for my choice of a V&H Slip-On made for the FLD. The o2 sensors are in the stock header pipes which stay on the bike.
Now these are a true set of Vance and Hines duals. The service dept told me how they did it... They took the new pipes sealed off the old O2 sensor locations since they were too large then modified the pipes with the correct adapter for the new O2 sensor. All in all if I were to go with a setup like this would run me just over a grand
i gotta get this old , chunk a steel off my table.., someone said these headpipes are stainless, if they are just steel , i'll cut the bungs out of them and put em in the staggered duals i got , ( they have no bungs, 06 02's were shunted) they where for 99 to 05's thnx for the pic wyld..
wyldspirit I think a grand is about right with what I’ve seen other charge. To me it’s a good deal actually. The only thing that was left out was Dyno Tuned. I was told you don’t have to do it, however you should fine tune it to get the max performance. Sounds good to me but I’m not an expert, as far from it as you can get.
I removed the catalytic converter from my 2012 Switchback. What i did was cut a window in the exhaust header where the cat is located, removed the cat and welded the header back together, the heat shield covers all welds.
How difficult was it? Do you have any pictures? Is it louder. I got a vance and hines slip on and I want more noise.
When I bought my Switchback in August the Nightstick was the only exhaust option. I had a pair of V&H Oval slip ons from my 05 Road King. I took the right one and made a couple of brackets, welded them on to line up with the original mounts, pipe diameter is the same, fit like a glove! I left the original hangers on the muffler, there not noticeable unless your bending down to look at them. [see pics]
