can i use this tank panel for a tach?
Old Nov 29, 2006 | 07:27 PM
waterman7474's Avatar
waterman7474
Default can i use this tank panel for a tach?
just got this of ebay, pretty cheap i might add.
but as i'm looking at it, i realize that it doesn't have the little hole on the side for the odometer button. that's probably ok since i can probably just drill one, right??
the second issue is the second hole (insert your favorite jab here!!).
it's 2 1/2 in across. now, there is a 2 5/8in tach, but it seems just as big as a speedo.
there is also a 2in one.
but, is the size # of the actual face or the OD of the whole thing?
whadda yall think? am i screwed? (i didn't spend much for it anyway)
BTW, i'll figure out where to put the idiot lights later but where are they on the bike it came off of??
and no................i've never had a problem with the second hole..........lets just get that out of the way!!
Old Nov 29, 2006 | 07:32 PM
PsTaN's Avatar
PsTaN
Default RE: can i use this tank panel for a tach?
That's the stock panel from a SuperGlide ... same as on my SG. The top is gas ... bottom is fuel guage. Dude probably replaced with a chrome one and sold that. Dont think you'll be using that for a Tach anytime soon. Sorry man.
PsTaN
Old Nov 29, 2006 | 07:39 PM
kpreese's Avatar
kpreese
I've never seen a tach shallow enough to even come close to fitting. Actually, you probably couldn't get the speedo in that larger hole either.
Kevin
Old Nov 29, 2006 | 07:46 PM
Mrkicks's Avatar
Mrkicks
That is definetely off a SuperGlide FXD....wanna buy another one!?
Old Nov 29, 2006 | 08:36 PM
Shrug's Avatar
Shrug
ORIGINAL: PsTaN
PsTaN
Huh?[sm=chairshot.gif]
Old Nov 29, 2006 | 09:20 PM
jackyl's Avatar
jackyl
here is a chrome one that will work for what you are looking to do.$24.99 here is the link tank panel
Old Nov 29, 2006 | 10:22 PM
DougsDyna's Avatar
DougsDyna
Yes you are screwed, unless you want to convert your Bob into a SuperGlide. LOL
The idiot lights on an FXD on part of the speedo bracket, and mounted on the handlebars.
DougJ
Old Nov 29, 2006 | 10:34 PM
PsTaN's Avatar
PsTaN
ORIGINAL: ktm_scott
ORIGINAL: PsTaN
PsTaN
Top cut-out is where one adds gas on a FXD ... the bottom is where the guage is installed. I cant see how that would work. Sorry I confused you enough to hit me with a chair!! [&:]
PsTaN
Old Nov 29, 2006 | 11:10 PM
waterman7474
yeah, i'm pretty much screwed. i stopped by the dealership on the way home (i just got it in the mail today).
one thing i didn't realize is that the speedo that goes in that panel is different, it's bigger. to that alone is enough to shut this thing down. and he didn't have any tach in (either the 2 or the 2 5/8) to test it in the smaller opening.
soooo.......................i got a black panel to sell!! like i said, it was cheap. i got a good deal to cause it's not cheap from the dealer.
while i was there, i looked into the ignition idea. the good news is that it looks like it will be relatively easy to get a ignition **** switch thingie in that area below the idiot lights. the switch is only like $130 and if i order it, they can key it to match my current key. i could then just use the front lock for locking the forks. the only thing we are unsure of is actually how it attaches to the panel from underneath.
thanks for the help.
Old Dec 1, 2006 | 11:33 AM
soup48's Avatar
soup48
Like the old saying, you get what you pay for, make sure you know what you need before buying.
Dysfunctional
EVO
Sep 17, 2012 10:52 PM
Clown Shoes
Aug 30, 2012 08:38 AM
saltydog1911
Aug 19, 2011 10:51 AM
MDER123
Jul 2, 2010 12:06 PM
carltex
Nov 28, 2006 09:43 PM
