red key light issue
Old Nov 4, 2011 | 07:50 PM
BrassHOLE's Avatar
BrassHOLE
Default red key light issue
well I've got a lil problem, i have no blinkers first off. but sometimes when i start my bike the red key light comes on and stays on. sometimes the bike immeaditally shuts off after i start it. and then sometimes it'll start and then a lil bit into the ride my bike won't idle and you have to keep it revved to make it run if you let off it'll die. i have replaced the key fob batteries just recently and can't figure out what to do. I'm almost positive it is not a short cause there are no wires to short as i have gone to different hand controls and like i said no blinkers
.....anyone
Old Nov 4, 2011 | 08:00 PM
PistonPuller's Avatar
PistonPuller
Red key light on means your bike threw a code. Do a code search and you should be able to narrow down the problem
Old Nov 4, 2011 | 08:15 PM
BrassHOLE's Avatar
BrassHOLE
uh how do i do a code search
Old Nov 4, 2011 | 08:21 PM
DCLXVI's Avatar
DCLXVI
Red key is not a code, the amber engine light is. Red key is your security system. Probably what is causing your problem. The module that controls your turn signals (TSSM) also controls your security system.
Old Nov 4, 2011 | 08:32 PM
BrassHOLE's Avatar
BrassHOLE
ok i did a lil searching and kinda found out what to do to retrieve the codes.
p=none
s=61121,61122,61145
sp=none
t=none
does this can anything to anyone
Old Nov 4, 2011 | 08:45 PM
DCLXVI's Avatar
DCLXVI
The codes under 's' are for your TSSM (turn signal security module). The ones you got are
b1121, b1122, and b1145. They are left turn signal fault, right turn signal fault, and security antenna fault respectively. Sound like a hack job gone bad. Hope this helps.
Old Nov 4, 2011 | 08:57 PM
BrassHOLE's Avatar
BrassHOLE
well i always will and probably always have had those left and right turn sig probs,but a while back i did unplug a module from under the seat and I'm guessing that was the antenna, all is back together and i have also rest the codes. i don't have any turn sigs nor do i have the rear factory taillight. i removed all of that stuff as did i the front and disconneceted the plugs so I'm pretty sure it wasn't a hack job.....
Old Nov 4, 2011 | 09:13 PM
PistonPuller
Red key IS a code. You can also have this without security. Amber is a code as well. Red key is associated with TSM or TSSM and engine light usually ECM
Old Nov 4, 2011 | 09:42 PM
Paracord Joes's Avatar
Paracord Joes
6th Gear
There is just something SO wrong about saying that when referring to a Harley....love my 12 year old Dyna....
HATZO1
Sep 4, 2018 03:29 PM
Gustoking77
Electrical/Lighting/Alarm
Jun 21, 2015 09:29 PM
juanmanuelrojascavaliere
Aug 3, 2011 01:00 PM
B-Duff
May 8, 2011 04:58 PM
bobby5
Mar 30, 2007 08:57 AM
