throttle and idle cable HELP!!!!!
I had a problem with the throttle not returning after I installed a new pair of grips. I found that the problem was that I actually installed the grip to tight to the end of the bar, and the end of the inside of the throttle grip was rubbing on the end of the handlebar. Which was causing it to get stuck. Took awile to figure out!!!!
Anyways, I re-positioned the grip just a hair out, and that fixed the problem.
Hopes that helps,
Shane-O
Hopes that helps,
Shane-O
scooper321
Apr 18, 2014 11:05 AM
