Busted throttle help ASAP
Old Jun 7, 2019 | 07:31 AM
Sorce's Avatar
Sorce
Default Busted throttle help ASAP
Roadside.
Have a hex keys.
Something snapped on my throttle 03 sporty.
Cabled.
Adjusted it out a bit this morning. Pulled back and popped loose.
Thanks!
Sorce
Old Jun 7, 2019 | 07:53 AM
Sorce's Avatar
Sorce
Default No longer roadside.
Rode her back home with the cable in my right hand.
Sure could use some tips to knock this out tonight.
Thanks Again!
Sorce
Old Jun 7, 2019 | 08:02 AM
shodown220's Avatar
shodown220
I would remove the switch housing on the throttle side and see if they cable just came loose of the grip, or if something is broken in there. If you were able to ride it home holding the throttle its gotta be something up around the grip area
Old Jun 7, 2019 | 08:06 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Most times it snaps at the little **** that rolls into the twist grip. Pop the housing off and look. There's no other way to find out whats wrong without opening it up to see. The good thing is its an easy and cheap fix if its just a cable.
Old Jun 7, 2019 | 08:18 AM
QC's Avatar
QC
I had a throttle grip fall apart where the cables wrap around. An ISO grip.
Old Jun 7, 2019 | 01:58 PM
Sorce's Avatar
Sorce
Default Thanks!
I Haven't found a tutorial on any grip related stuff yet.... recommendations?
Figured I might rotate my levers back a bit too to compensate for my bars morward.
Sorce
Old Jun 7, 2019 | 02:19 PM
Zerk's Avatar
Zerk
You are home, nor on the side of the road?
IMO saying ASAP should be used for people broke down.
But ya take it apart put it back together. If cable broke buy a new one. I believemanual covers this,better than how I use to force things with needle nose and swearing..
Old Jun 7, 2019 | 03:01 PM
Cogswell's Avatar
Cogswell
If you don't have a clue about what your doing it would probably be safer in the long run to take it to someone that knows how to fix it properly. It you try to fix it and fail, you may end up with the throttle sticking wide open at an inopportune time. That could end up hurting you seriously, or killing you.
Old Jun 7, 2019 | 07:27 PM
Sorce's Avatar
Sorce
Thanks, oh, I was a bit nervous where I was, and had to unload a truck at work and would push the bike a mile before calling a tow.
Thanks!
Wish I knew how to maneuver this site a little better.
Old Jun 7, 2019 | 07:33 PM
Sorce's Avatar
Sorce
Thanks.
I hope to get original parts and the service manual tomorrow. I trust my hand and OEM.
Got the Air cleaner off until the last socket I don't have. So far so good.
O'Reilly sent me $20, so along with my .62 cent turnlamp and these new hex sets...my HD costs shouldn't hurt much.🙉
Sorce
