In order to...
Old Nov 15, 2011 | 12:05 PM
emerican19's Avatar
emerican19
Default In order to...
Take off rigid sideplates/sissy bar, do turn signals need to be removed? I haven't cracked it open yet, but look at pictures it appears theres a hole that the rear signal wiring runs through.
Old Nov 15, 2011 | 12:08 PM
ynots's Avatar
ynots
Not necessary to remove signals, the side bracket is slotted for the wires to pass through
Old Nov 15, 2011 | 03:51 PM
emerican19's Avatar
emerican19
Sorry guys i feel like a dumbass.....I'm midway through the project in an apartment complex so i've just got parts laying in the parking lot.
Both outside torx bolts are removed, the thing wont budge. Is there something else securing the sideplates up under the fender?
Old Nov 15, 2011 | 04:17 PM
emerican19's Avatar
emerican19
somebody somebody?
Old Nov 15, 2011 | 04:25 PM
dsiltman's Avatar
dsiltman
There is a bracket inside the fender that sticks through it on each end.
Old Nov 15, 2011 | 04:31 PM
dsiltman's Avatar
dsiltman
Do you have the bolts out on the inside of the fender at the rear that go into the turn sigs. You do not have to take them off but you do have to take the bolt out that holds them and let them hang. Do one side at a time or your fender will fall down.
Old Nov 15, 2011 | 04:37 PM
emerican19's Avatar
emerican19
I appreciate the response, are they INSIDE the fender, like up under be the wheel or somehow between the sideplate and the bracket. What type of head is on the bolt (allen, phillips, torx?) Thanks.
Old Nov 15, 2011 | 04:41 PM
dsiltman's Avatar
dsiltman
Feel inside the fender behind the turn sig I believe they are 1/2" wrench.
Blaque_Nite
Apr 2, 2019 07:53 AM
blink1968
Jan 26, 2012 09:24 PM
rosshog
Feb 24, 2010 08:47 PM
mebe007
Mar 9, 2009 06:33 PM
FBFletch
Mar 16, 2006 08:00 PM
