Lowering a Street Bob
Old Nov 16, 2011 | 08:27 AM
SBRob's Avatar
SBRob
Originally Posted by SPECIAL ED
Like somebody already said with your low weight lowering blocks will probably work best.The reason many stay away from them is that they change the angle of the shock which softens the ride and may cause your shocks to bottom out. Weighing in at 90lbs this will not be an issue and will probably improve the ride.I also wouldn't start messing with the front unless you have to, sliding the tubes up in the trees up to about an inch will accomplish allot without effecting ride quality and costs nothing.
Good advise...IMO, no need to pay for shorter shocks and fork springs for a 90lb rider to lower the bike.
Old Nov 16, 2011 | 08:52 AM
rounder's Avatar
rounder
at 90 lbs I would seriously think about putting a good shock on your bike...go with an Ohlin, Ricor or works performance that is shorter than stock(11" or 11.5"). Considering that off the shelf shocks are more tuned to a rider 175-200lbs a shock tuned to your weight will be very well served.
Old Nov 16, 2011 | 09:00 AM
WG2011's Avatar
WG2011
My thoughts as well, at 90lbs your going to have a rough ride because there is not enough weight to compress the shocks.
WVICEMAN
EVO
17
Nov 8, 2016 08:22 AM
TxFF636
Sep 30, 2013 03:37 PM
antman27
Oct 15, 2011 08:54 AM
Billie
Mar 4, 2009 08:40 AM
ddsglide
Jan 19, 2009 09:25 PM
