Me 880 ?
Old Nov 20, 2011 | 11:00 AM
JimmysFXDC's Avatar
JimmysFXDC
Default Me 880 ?
Just put one on the front after being on Dunlop GT 502f for many years. This is the first time I've expirienced the front having a heavier steering feel after replacing the front tire, even if the rear tire only had a couple thousand miles left on it. I was just wondering if anyone else encountered this. I'm pretty sure I can remedy this by adjusting the ride heigth on my shocks, but I wanted to know before I start screwing with my suspension adjustments.
TIA
Old Nov 20, 2011 | 11:21 AM
EricInNCa's Avatar
EricInNCa
That is an interesting observation. I can't imagine why the front would have a heavier steering feel only after replacing the tire. Did you go with the same size? Tire pressure set OK? No other changes to the chassis setup? I wouldn't start changing my suspension just because of a tire swap. To me, that doesn't make sense. Perhaps someone else may chime in with a logical explanation....
Old Nov 20, 2011 | 11:26 AM
desertrideryz's Avatar
desertrideryz
That's kinda weird I've had mine on for year now and it feels the same as the dunlop
Old Nov 20, 2011 | 11:29 AM
JimmysFXDC's Avatar
JimmysFXDC
Same size 100/90 19, pressure is good.
Old Nov 20, 2011 | 11:55 AM
Rmuller's Avatar
Rmuller
Maybe its just holding the road better??
Old Nov 20, 2011 | 12:07 PM
Mascman's Avatar
Mascman
what pressure are you running?
Old Nov 20, 2011 | 12:21 PM
JimmysFXDC's Avatar
JimmysFXDC
38 psi on front metz and 40 on rear dunlop screaming eagle 180
Old Nov 20, 2011 | 06:01 PM
DCLXVI's Avatar
DCLXVI
I know Metzler recommends higher pressures in their tires than what the factory specifies. I don't recall exactly what the figures are though.
Old Nov 20, 2011 | 06:07 PM
TORQUEY's Avatar
TORQUEY
I don't know about THOSE Dunlops, but I noticed that my bike handled way "lighter" feeling when I switched out the Dunlop 407/408 tires for the Metz ME 880's. The tires, although brand new, felt glued to the road, and yet the same bike felt more maneuverable. Very significant handling improvement.
Old Nov 20, 2011 | 06:18 PM
Mascman's Avatar
Mascman
I run 40-41 in my front. I run the Metz 170 on the rear and run 45 in it.
