V&H Side Shots install notes
Old Nov 20, 2011 | 12:32 PM
Tuffstang's Avatar
Tuffstang
Default V&H Side Shots install notes
I just installed these Vance & Hines Side shots (PN#26001) on my 06 Street Bob with the quiet baffles (PN#21301).
My notes to start are:
When installing the quiet baffles use scotch tape to tighten down the new wrapping. Make sure you line up the holes first and they slide right in.
Take off the passenger peg, battery cover, seat and air cleaner cover. Make sure to cover the motor with a towel & shop rags. Get the 3M blue masking tape to protect the heat shields by the flanges. Tape off the frame and fins near the exhaust ports with double thickness of the tape.
Do not install the oxygen sensors until last and everything is on. Leave the heat shields loose and do not install the new bracket to the transmission yet. Without the bracket on it makes it easier to fit the new pipes to the heads. The new bracket will go on fine once the pipes are loosely bolted on. The key here is keep everything loose until you have everything on and checked.
Start with matching up the front pipe to the exhaust port. I used a small piece of PVC piping wrapped in duct tape for leveraging the pipes around. A small card board box helps keep the pipe tips protected and off the ground. The trick to lining up the rear port is lifting up on the pipes. Take your time, after a couple attempts they just fall in. No need to pull or spread the pipes apart.
Attached Thumbnails V&H Side Shots install notes-img_0056.jpg   V&H Side Shots install notes-img_0080.jpg   V&H Side Shots install notes-img_0081.jpg
Old Nov 20, 2011 | 01:47 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Nice job. Bet it sounds cool.
Old Nov 20, 2011 | 02:30 PM
art0565's Avatar
art0565
Great tips, thanks
Old Nov 29, 2011 | 05:45 PM
Tuffstang's Avatar
Tuffstang
Default sounds cool!
Thanks,
The exhaust does sound cool, thumps rather than rasps. Before today I really only started it twice in the driveway. I broke my hand 8 weeks ago and actually today I finally took it out for a ride. The install wasn't bad with one weak hand.
There's a big sound difference from SEII slip-ons I was running. The V&H Side Shots definitely bring back the low-end torque, due to the power chamber or quiet baffles. You can feel the difference right away throughout the power-band. Oh yeah and they look cool too, not that standard exhaust configuration.
Old Nov 29, 2011 | 06:53 PM
jupiter2's Avatar
jupiter2
In my opinion, they are the coolest looking pipes - so you are happy with the performance?
Old Nov 30, 2011 | 11:12 AM
Tuffstang's Avatar
Tuffstang
Default performance
Yes, I'm happy with the performance. I am running a Fuel Pak, quiet baffles and Stage 1 K&N air filter. Maybe one day some cams & ignition.
Old Nov 30, 2011 | 05:46 PM
2009Bobber's Avatar
2009Bobber
Love that pipe.
Looks awesome.
Peter Chadwell
Jul 12, 2016 07:34 PM
Jfree700grizzly
May 24, 2015 10:32 AM
carpwkc1
Mar 8, 2013 10:13 AM
Double Trouble
Nov 28, 2012 10:26 AM
CoffeeGuy
Exhaust System Topics
11
Aug 22, 2011 05:11 PM
