Brake Light Problems
Old Nov 25, 2011 | 04:01 PM
dennyclutch's Avatar
dennyclutch
Stage II
Default Brake Light Problems
I Have a 2007 FXDB Street Bob. My Brake Light is inop I have switched to LED and Still no Luck all the Fuses are Good and I have back Probed all of the Wires I am Getting Power to the Tail Lamp Just not the Brake Light What am I Missing.?
Old Nov 25, 2011 | 04:39 PM
bobnehoc's Avatar
bobnehoc
Stupid question but when you checked for power at the brake light did you try both the front brake as well as the rear. It could be as simple as a bad brake light switch.
Old Nov 25, 2011 | 06:50 PM
08fxdf43202's Avatar
08fxdf43202
Remove the two wires from the rear brake light switch and jumper them together with the ignition on... if the lamp lights you've got a bad switch.
Old Nov 25, 2011 | 07:17 PM
CoyoteQuick's Avatar
CoyoteQuick
I agree on checking the brake light switches, if all else fails...check the loose nut behind the handle bars and above the seat (LOL). Then get a service manual and check the wiring diagram for connector locations.
Old Nov 26, 2011 | 10:43 AM
dennyclutch
Stage II
I Have the Service Manual. I Have followed the wire diagrams and checked for Power at the switches. Power is presant when I Press the Brake Pedad or use the Handle I Have no Power Drop. I have Power in all of the wires. Is There a Common Module or controller? I have removed the seat and checked for Power at the Wires. The Book Does not give me much information.
denmaz
Electrical/Lighting/Alarm
Sep 4, 2015 09:46 AM
Briguy1
Feb 9, 2015 06:10 PM
Deelux
Jul 30, 2012 08:40 PM
HogFather
Feb 16, 2009 11:53 AM
SIDEWAYZ50
May 23, 2006 08:32 PM
