Brake light switch questions...
Old May 23, 2006 | 10:44 AM
SIDEWAYZ50's Avatar
SIDEWAYZ50
Stage IV
Default Brake light switch questions...
Brake light staying on my '87 fxstc - I did a search and found some good info, but nothing I tried fixed my problem. I checked both front and rear brake light switches - both had continuity. Nothing changes when you press either front or rear brake lever, light always stays on. I took the front brake light switch out, and worked the plunger tip by hand, should this have made the light go on and off normally? Bad switch even though it tested ok? Any help would be awesome, thanks.
Old May 23, 2006 | 02:50 PM
DGlide04's Avatar
DGlide04
Default RE: Brake light switch questions...
You could try looking inside the tail lamp at the bulb and connection for the brake light. If it got wet and has corroded, it might be making a complete circuit w/o even working the brake lever or pedal. Just a thought if everything else seems okay.
Old May 23, 2006 | 08:32 PM
SIDEWAYZ50's Avatar
SIDEWAYZ50
Stage IV
Checked all that out and cleaned all the connections...anybody else?
uride2
Electrical/Lighting/Alarm
Apr 4, 2017 05:47 PM
denmaz
Sep 4, 2015 09:46 AM
Deelux
Jul 30, 2012 08:40 PM
cnewty
Jun 23, 2007 01:29 AM
ian
Feb 6, 2007 07:16 PM
