Upper fork covers?
Old Dec 7, 2011 | 08:05 PM
KungPowMinchow's Avatar
KungPowMinchow
Originally Posted by Grich171
looks good what do you mean by dlc?
the tubes are diamond like coated
Old Dec 7, 2011 | 08:10 PM
Northern B's Avatar
Northern B
thanks for the link but holy moly 230 for two pieces of tube yikes!
yeah thats my thought too, lotsa coin but gives a person ideas as to what can be done for making something different and sending for powder coating, especially if you know a buddy with some machining equipment
Old Dec 7, 2011 | 10:20 PM
Stag556's Avatar
Stag556
What does something like that cost to have done?
Old Dec 7, 2011 | 10:51 PM
Nick_N's Avatar
Nick_N
Check out Race Tech's website, they'r selling coated fork tubes in 4 different colors for around 180 I think. http://racetech.com/page/title/TNK%20Fork%20Tubes
Old Dec 8, 2011 | 10:16 AM
KungPowMinchow
Its not a straight forward procedure to DLC the forks ( Diamond Like Coating ) as the process is a high pressure, high temp deal and you need to cut the lower damper ring off the stanchion using a lathe and then TIG it back on after the coating.Diamond Like Coating is the toughest coating known and literally covers the surface in micro diamonds, making it ultra hard and friction free, so its ideal for forks, cam lobes etc. Pete from Rocket Bobs do mine and they turned out awesome! He does amazing work but heres his link to his website.
http://www.rocketbobs.biz/
Old Dec 8, 2011 | 04:06 PM
Handsome's Avatar
Handsome
I made mine myself in 2 pieces of aluminum pipe and had it powdercoated. Makes the fork look more beefy than the PVC pipe.
Attached Thumbnails Upper fork covers?-260574_l.jpg   Upper fork covers?-260578_l.jpg   Upper fork covers?-260580_l.jpg
Old Dec 8, 2011 | 04:32 PM
Stag556's Avatar
Stag556
That's an excellent idea. Do you know the measurements of the pipe off hand?
Old Dec 22, 2011 | 04:22 AM
nabosler's Avatar
nabosler
1st Gear
Mine are done with 3m car wrap vinyl. It's a little tricky, but with some help and a heat gun it turn out pretty nice for less than 20$.
Old Apr 25, 2013 | 02:30 PM
riverismine's Avatar
riverismine
Default length??
im gonna get a shop to cut some aluminum tubes for me so you guys know the exact lenght to be cut is it 180mm or 181mm for 2009 sportster Iron??
i dont have a electronic scale long enough to get correct measurements...
Old Apr 25, 2013 | 02:46 PM
SLV's Avatar
SLV
http://www.amazon.com/3M-1080-Matte-.../dp/B007856N1K
$18. Comes in gloss, flat, Carbon Fiber look, etc. takes 5 minutes to apply. Maintenance free and durable. I've had it on for 3 months and 3200 miles. It looks the same as the day I applied it.
It fits through the clamps too, in case you need to disassemble the forks.
