got a DTC need help with
Old Dec 14, 2011 | 10:39 PM
BrassHOLE's Avatar
BrassHOLE
Default got a DTC need help with
p0154
rear 02 sensor open/not responding
my brothers 08 fat bob has had a lil issue since we put the power commander 3 on it and i can't figure out what to do. it will sometimes stay on high idle when coming to a red light and will stay that way for some time even if the bike is warm. i called power commander and they told me that in no way was it the tuner, i asked if it could be the 02 eliminator and was told that he had never herd of one going bad. and proceeded to tell me that the code being thrown could lead me elsewhere on the bike like the IAC or TPS does anybody have any suggestions.
Old Dec 15, 2011 | 01:27 AM
Foxster's Avatar
Foxster
Yup. Remove the PC, refit the O2 sensors, clear the codes, run the bike and see if the codes come back.
Old Dec 15, 2011 | 02:48 AM
BrassHOLE's Avatar
BrassHOLE
so then i should go ahead and take off the exhaust and the big sucker also. nope i see the prob shouldn't have bought a fat bob,
Old Dec 15, 2011 | 03:10 AM
missedem's Avatar
missedem
sounds like the 02 sensor eliminators trigger a diagnostic code when you use them? Its possible the diagnostic system only thinks there is a problem and triggers a code when the problem is only that the o2 sensors are not being used and its confusing the computer.
As far as the high idle goes my 2011 Street Bob did this during the summer time. I called HD and asked there technical guys and was told the higher idle is just the engine idling higher to cool itself off . I have never had my bike run bad (2011 Street Bob) but when the weather is hot and the motor gets hot when I pull up to a stop light the motor always idles high until the temperature drops some and the motor starts to cool off a little bit.. It takes some getting used to it , the idle can be as high as 1500 RPM . this is normal for an efi bike. It will do this even with some aftermarket tuners. I have a TV3 and it still does it. If it revs higher than about 1500 id call the HD shop and tell them you have a problem. Don't be surprised however if they don't blame the PC3 .
Old Dec 15, 2011 | 03:14 AM
missedem's Avatar
missedem
this is not new news but they really should have included an oil cooler stock on these bikes to help manage the temps better. Re - tuning helps but does not eliminate the problem completely. the twin cam motors just run hot .
Old Dec 16, 2011 | 01:35 PM
monkeyboy22's Avatar
monkeyboy22
How does an air cooled motor's cooling system benefit from a high idle? I could understand if it were liquid cooled to keep the fluid moving with the (water) pump but, air cooled?
Old Dec 16, 2011 | 01:46 PM
Mr.Guns's Avatar
Mr.Guns
p0154
I JUST had the same issue yesterday after installing my PC3 on my 07 FXDC. Turned out the O2 sensor eliminator with the PC3 WAS bad, there was a broken wire. You can check yours with a multimeter, just check for 1 Ohm of resistance between the two wires on the eliminator. I ran to Radio Shack, picked up a 1 Ohm, 1/4 watt resistor (5 pack, $1.19) and connected it to the O2 sensor wires (a jumper basically) coming from the computer. Cleared the codes, and everything is fat & happy now. That's all the O2 deletes are, resistors.
Here's what you need from Radio Shack:
http://www.radioshack.com/product/in...ductId=2062351
Old Dec 16, 2011 | 03:35 PM
dirtdobber's Avatar
dirtdobber
A high idle is very common on some of the bikes. My Ultra does it at times.
What code does it throw?
that may lead to the problem. I am not so sure it is the PC3 unless it is not have good connections. Is it a plug and play type?
However, you can disconnect it and reconnect he o2 sensors without removing everything just to see if it does it without it. I don't suggest taking a trip though. long enough to get it at full operating temperature.
So it idles correctly until it warms up?
If you bought it from fuelmoto they have a very good warranty and they will replace it without any questions or tell you what it may be.
just a thought
dd
Old Dec 16, 2011 | 03:51 PM
kk6pg's Avatar
kk6pg
I have a question for you...
Has a "check engine" light been thrown?
If not, dont worry about a p0154 code. Its one of the codes we ignore when we see it, unless its associated with a check engine light. Even then, if you have O2 eliminators, you could have a bent/broken pin in the connector, or the eliminator took a dump.
I will say this, the P0154 code and the high idle are NOT related.
If you want to put a bandaid on the high idle, shoot some carb cleaner down the port for the IAC and clean the built up gunk out of it. This will usually work for a while, until the IAC finally gives up the ghost. Then replace the IAC.
You'll know when the IAC goes. The bike wont idle at all.
AreTee
May 3, 2018 05:36 PM
rebel7
Aug 7, 2017 09:36 AM
DanDman
Jun 23, 2012 01:36 PM
RoadTramp113
Apr 25, 2011 09:25 AM
cnielsen4130
Oct 10, 2007 10:45 PM
