So after installing my heavy breather and pcv on my 09 Fat Bob. I tried starting it up only to find out I needed a new battery. So with all this replaced she cranks but won't fire up. I get no spark at the plugs and have an engine code of P1353- which is front cylinder no combustion. I order a new voltage regulator from the dealership. Any other ideas of what it could be?
maybe before you installed the breather and pvc you had issues.
May not have anything to do with the mods installed. Try using the standard code closest to stock. With a new regulator it should work. Once you get it started you can try getting more aggressive with some codes to see how it runs and what gas mileage you end up with.
Good luck.
I've been following your other thread on the bike not starting. Now that your battery problem seems to be under control, have you checked your spark plug wire orientation. It sounds like with all the fiddling you've done, theres a real good chance you have the plug wires reversed at the coil.
The plug wires are probably not getting a good connection to the coil for some reason. Use some oxide inhibitor on the connections. Then reset the codes.
