battery tender
Old Dec 23, 2011 | 09:03 AM
South Jersey Scooter Trash's Avatar
Default battery tender
Anybody use solar powered battery tender do they work?
Old Dec 23, 2011 | 09:08 AM
Romark's Avatar
Romark
I'm sure it does but if you keep your bike in the garage it won't work. There is no light in my garage except for when the door it up. If you have a window I suppose that would work but I'm not sure how much light they need. Direct sun light?
Old Dec 23, 2011 | 09:18 AM
Gliden's Avatar
Gliden
I never had a solar anything that I thought really worked "well".....
Old Dec 23, 2011 | 09:29 AM
I have a window right next to the bike was going to mount the panel outside and run leads through window.
Old Dec 23, 2011 | 09:41 AM
ImNoPrince's Avatar
ImNoPrince
I have been using one for 2 years now. My Garage is 3 blocks away with no electric. I use to do some work on Boats and installed a few on them for some people.
I mounted my panel on the roof where it would get max exposure but also be protected. It won't charge but does maintain up to the few months at a time as I do get a ride in every now and then like maybe today I hope.
Old Dec 23, 2011 | 10:19 AM
Bluehighways's Avatar
Bluehighways
Make sure that the Solar Panel uses diodes. When the sun goes down a solar panel will actually consume power. That said, I had a place up in the mountains with an automatic electric gate where the driveway came to the street. The gate opener used a motorcycle battery and a 1 ft square solar panel to keep it charged. Over 5 years with no problems and the battery that was in it, was there when I bought the place, and was still there working just fine when I sold it. So I have no idea how old it was, but it always worked just fine. Then again, running the pump for a hydraulic ram, even on a 4' X 12' Steel Gate, isn't quite the same thing as cranking an engine over.
2ropes
Mar 31, 2014 06:10 AM
hogowner69
Nov 11, 2013 07:05 AM
bra$$monkey
May 6, 2011 06:55 PM
melrose68
Jul 1, 2007 09:57 AM
1flhtk4me
Oct 26, 2006 10:02 AM
