Dyna Floorboard comparison
I looked at everything I could find (Pics. included) and determined that the Wyatts were more level with the ground, and a little further back.
I chose the boards for the FLD because the brackets come out below the pipe, where the Wyatts come over the pipe. This allows the boards to be slightly lower in the rear. Plus, the FLD's are an inch or so more forward.
Take a look. If you are intrested, There is a list of PN's with prices and notes for all the stuff you'll need here on the forums. just "search" "floorboards on a Dyna"
If you are putting them on an '06 or newer, the FLD's work well, and look like they've been there all along. '05 and earlier, I can't say for sure that they would work.
Another thing to concider is the exhaust you have on. I run V&H Big Guns, and had to cut away part of the heat shield for clearance on the R/H aft bracket. It's no big deal, But on some exhaust, it could be a showstopper.
http://s1203.photobucket.com/albums/bb395/Harley_Tim/
Hope this helps.
Best wishes, and Merry Christmas....Tim(HT)
The list I mentioned earlier list a lot of combiations. I had HD forward controls, and was able to use some of those parts. Lowering the cost a lot.
Here's the list I mentioned:
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the brake:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For ’96-’00 models
34639-01 RETAINER $ UNK (See note #4) For ’01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the ’12 HD custom book (I’m not real big on chrome) and my parts guy gave me a set of stock “take off” standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
__________________
RVN '70-'71, USA, RET
'06 FXDi Super Glide with lots of stuff.
It's not rust.....It's patina!
For reference, I'm 5'10, 31" inseam, 192 lbs., and I have a Mustange Vintage Wide seat with backrest. I also have a f*cked up lower back, I'm constantly battling sciatica and have a neck that was finally put back together correctly in 2008 after breaking it in 1971 on a dirt bike.
