FLD on a Sears Jack
Old Dec 30, 2011 | 09:51 AM
cecharles's Avatar
cecharles
Nice job!!
Old Dec 30, 2011 | 10:15 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by tubby220
Damn I rather hoped I could use the Dyna blocks I used on the streetbob!
Why would anyone HOPE for the blocks to continue to work. I'm sure they do as that's a Dyna frame and the dyna frame requires the blocks if you're going to use a regular (not expensive) bike jack. If you want to spend $300-$400 on a jack that doesn't require the blocks (buiilt wider to accommodate the irregular frame), go for it. If you're into saving some cash then buy a sears jack and do the $10 mod to it. You'll have a sturdy lifting device at a very reasonable cost.
The blocks are junk IMO. Why would you design something in two pieces if you knew it was going to be a vital part of lifting the motorcycle? The least they could have done was make it a one-piece design. I had one of my adapters separate while the bike was on the lift. They are a hassle to line-up to get the bike/lift adapaters square on the jack.
Just do the mod and save yourself the headaches.
My motto: No adapters needed.
Old Dec 30, 2011 | 10:19 AM
SC-Longhair
Originally Posted by G.O.D.
I did a Search on this Site for a Sears jack and got the Info from SC-LongHairs Post Called Sears red jack modification . He also has a Video. I will go step by step. 1. In the Begining I gathered my Tools. 2. Used a Sawsall to cut the Bar Between the Riser Plates. 3. Used a Hand Grinder to Smooth the Bung Hole that was left. 4. Used a Half Inch Drill Bit to Enlarge all 4 Holes Then Reversed the Riser Plates. I used 1/2 inch by 6 inch Grade 5 Bolts, Nylox Nuts and Fender Washers. I think you could get away with 5 1/2 inch Bolts. Takes a little Finagling to get it just Right under the Bike. Works great.
After looking at your pictures (Very nice by the way), I noticed you didn't transpose the front left (in last pic) bolt around. I'd think the threads would interfere with the kickstand. That's what I ended up doing, was just flipping the bolt around so the head was on the outside.
Old Dec 30, 2011 | 10:30 AM
mrnone's Avatar
mrnone
I can make something if there is a void in the market for a bitchen dyna lift block.
I need money as much as the next guy.
haven't had to deal with it on this bike but my back tires about gone and I really want to black my legs out...
I am thinking machined delrin channels backed up by 1/4 inch plate mated perfect to a dyna frame clearing all the accessories/boards/whatever.
Old Dec 30, 2011 | 11:03 AM
8541hog's Avatar
8541hog
Why make this more difficult than it needs to be? SC's remedy works flawlessly and is cheap, quick, and easy, all the qualities I love in my women...er I mean mods.
Old Dec 30, 2011 | 11:11 AM
Ben E's Avatar
Ben E
I just got this jack as a present. Is it going to require mods to lift my 2011 FLHR?
Old Dec 30, 2011 | 11:12 AM
8541hog's Avatar
8541hog
Never lifted an FLHR, but I believe this mod is only required for Dynas.
Old Dec 30, 2011 | 03:08 PM
SwitchHD's Avatar
SwitchHD
Took about an Hour to Modify the Jack. works Great.
Beautiful ride! Good luck with that.
Old Dec 30, 2011 | 05:28 PM
SC-Longhair
Just so we're clear, the jack doesn't *need* to be modded for the dyna but it sure makes life easier.
As for your FLHR, I believe your frame is flat all the way across the bottom so, no you don't need to mod your jack but it may help with stabilizing the bike a little more while on the jack.
The lift pads are kind of narrow. Give it a shot. Worst comes to worst, you set the jack back to oem.
The mod takes ~15-30min and $10 in nuts/bolts/washers.
Old Dec 31, 2011 | 12:01 AM
G.O.D.'s Avatar
G.O.D.
Your right I forgot to do that , I don't remeber hittin the Stand. I'll try it this Weekend. So you feel this is Stable enough to pull my front end off? I'll strap the Bike down .
