Also...put a bead on header/pipe joint to prevent leak(s) right @ pipe clamp. I squeeze a ring out inside pipe & smear w/finger - makes nice/tight seal.
I purchased long nuts that cover all the stud thread so I didn't use anything.
I used new graphite exhaust gaskets.
Anti-sieze is ok for the pipes connections but I would use the blue loctite or nothing on the studs.
Double nutting is ok if you have the length.
any metal bolt that threads into a piece of aluminum that does NOT use a heli coil should be treated with anti-sieze. metal to metal should have locktite. use sparingly only on the first few threads and wipe off excess.
Using loctite on the exhaust flange nuts will not accomplish much of anything, as hot as those get it I doubt it would ever fully cure to give you any benefit. You guys do realize you use heat to loosen bolts that have real good loctite on them right?
