Antiseize
Old Dec 31, 2011 | 04:42 PM
jo_mama's Avatar
jo_mama
red locktite is good to 450 degrees F
if they keep coming loose i recommend using these.
https://www.denniskirk.com/4404240.s...utm_medium=cse i used these on my headers in my 70 chevelle and they never came loose because it is impossible.
Old Dec 31, 2011 | 04:44 PM
8541hog's Avatar
8541hog
They get much hotter than that. Around 600.
Old Dec 31, 2011 | 04:47 PM
jo_mama's Avatar
jo_mama
i checked my head temps after riding 50 miles with my IR gun and they were 330F
Old Dec 31, 2011 | 04:54 PM
Harley Tim's Avatar
Harley Tim
Well.... Antiseize is mostly intended to be use in applications where there is dis-simular metals, i.e. steel sparkplugs into aluminum heads, stainless steel into heli-coils, and such.
The Moco recommends not useing antiseize on the head-pipe studs.
From my personal experience I've found using it is better. However then they are likely to vibrate loose. That is why previously I recommended 2 nuts per stud. It keeps them from backing off.
What ever works for you...It's all good.
I tried installing them dry and re-torquing them, and after 2-3 days checking them, they did stabilize. But I still wasn't confident they would stay.
What the he!!, put on the antiseize. It makes them way easyer to remove.
Just my $.02
Best wishes....Tim(HT)
Old Dec 31, 2011 | 04:59 PM
jo_mama's Avatar
jo_mama
re torque on the exhaust studs is critical even if you double nut, use locking bolts, etc. good advice for sure.
Old Dec 31, 2011 | 05:01 PM
Flinter's Avatar
Flinter
Thanks for the thoughts guys.
I had considered the fact that as much as my Dyna shakes it may be a bad idea. I'm installing the pipes tomorrow so I guess I have the whole night to think about it.
Of course, I bought beer...so maybe I had better think about it now!
Old Dec 31, 2011 | 05:04 PM
jo_mama's Avatar
jo_mama
anyone ever find the best way to remove silver anti-sieze from skin? LOL that crap is hard to remove! i usually ***** out and wear rubber gloves.
Old Dec 31, 2011 | 06:23 PM
neocontra's Avatar
neocontra
Orange cleaner gets it right off my hands, every time.
Old Dec 31, 2011 | 06:54 PM
Harley Tim's Avatar
Harley Tim
For sure.... Once they stabilize..... put on the other nut ,and lock it down. They're not going anywhere.
Best wishes, and Happy New Year!! Tim(HT)
Old Dec 31, 2011 | 07:02 PM
Harley Tim's Avatar
Harley Tim
You're not "pussyin' out"! That stuff is poison!! Nothing wrong with taking nessisary precautions.
Remove it when you peel off the gloves...
Best wishes, and Happy New Year! Tim(HT)
