Saddlebag Mount Help
Old Jan 12, 2012 | 07:39 AM
cbky71's Avatar
cbky71
Default Saddlebag Mount Help
I bought these off eBay and need help figuring out how to mount these. The part number is 90461-06a. Any ideas. Thanks.
Old Jan 12, 2012 | 07:40 AM
cbky71's Avatar
cbky71
Here is the correct picture.
Old Jan 12, 2012 | 07:41 AM
cbky71's Avatar
cbky71
If anyone knows where I could get to of these emblems that would be great also.
Old Jan 12, 2012 | 10:55 AM
Garyk's Avatar
Garyk
Are these for the 2012FXDC? If so don't think they will fit to good. That bottom bracket is not used on mine anyways. The bags look like they were QDs no?
Old Jan 12, 2012 | 11:04 AM
cbky71's Avatar
cbky71
Yes they are the QD one's and are for the my 2012 FXDC. The mounting holes line up on the fender supports just need to move the turn signals. I can take the bottom mount thing off the saddlebags because like you said there isn't anywhere to mount it. I'm just not sure what I can use to mount them if anything. I thought about taking the QD mount off the bags but they are riveted on there. I could probably cut them off. Thinking I may have to re-sell them. I like'em alot. They look good when I hold them next to the bike. Thanks for the reply!!!!!!!!!!!!!!!!!!
Old Jan 12, 2012 | 11:52 AM
1HD1C's Avatar
1HD1C
get some easy brackets or edge ( i think thats the other company brand) to mount them.
then drill the rivets out, once you get the heads off they will fall out and then use the other brackets to mount the bags to the bike.
Old Jan 12, 2012 | 12:12 PM
cbky71's Avatar
cbky71
Sounds like an idea. Will look those up now.
Was wondering if I got the detachable saddle bag mounts that go behind the fender strut which in turn gives me a mounting point if those will work. Probably not....just thinking out loud.
Old Jan 12, 2012 | 12:49 PM
Ratbob's Avatar
Ratbob
See if this post gives you any ideas.
Old Jan 12, 2012 | 01:07 PM
cbky71's Avatar
cbky71
THANKS!!!!! I don't have the QD backrest....wonder if I could modify it a bit to work with mine.....it's winter time so time to tear the rear apart.
Old Jan 12, 2012 | 02:54 PM
TGWN's Avatar
TGWN
Thanks for the idea.
