Saddlebag Mount Help
Old Jan 13, 2012 | 08:57 AM
cbky71's Avatar
cbky71
Originally Posted by fskitch
http://www.ebay.com/itm/TAIL-LIGHT-P...item45ff7ec3c2 You can install this tail light with built in blinkers and loose the stock stalked blinkers. Replace the fender bolts and add 3/8" all thread, lock in place with a bolt. Remove the quick release stuff and cut the all thread so a washer and acorn nut fits to hold bags on. Use a spacer and acorn nut when not running bags. A search on this forum should provide instructions.
Excellent info. Think I may go with that light. Just replaced mine with smoked LED lay down but doesn't have the turn signal built in.
Old Jan 13, 2012 | 09:24 AM
Harley Tim's Avatar
Harley Tim
Originally Posted by cbky71
Would you happen to have a picture of how yours are mounted?
I'll try to get some on my "Photobucket" later today..
Old Jan 13, 2012 | 10:31 AM
cbky71's Avatar
cbky71
Thanks man!!! Really appreciate it!!!
Old Jan 13, 2012 | 12:39 PM
Harley Tim's Avatar
Harley Tim
cbky, Here are some photo's of my mounts. They are with others of my footboard mod. using FLD parts, if your intrested. I just added them to that folder.
I've got the bike set-up "convertable style" to accomadate any combination. One up, two up, with /without sissy bar, with/without luggage rack, and with/without saddle bags. All easily changed within 1-2 min. When I tour, I usually remove it all when I get to my destination to clean up the look while puttin' 'round the local area.
You'll notice that the lower fwd mount on the bag, and the bike are dog-legged. That is the quickest way to tell the difference between the old (like yours) and the new. What that did, was moved the bracket from behind the shock (out of sight w/ bags not installed) out into the open. Making it much easier to change the docking bushing when it wore out. And they do! I usually change or rotate them about twice a year
http://s1203.photobucket.com/albums/bb395/Harley_Tim/
Hope this helps.
Best wishes....Tim(HT)
Old Jan 13, 2012 | 12:48 PM
cbky71's Avatar
cbky71
I've got the bike set-up "convertable style" to accomadate any combination. One up, two up with /without sissy bar, with/without luggage rack, and with/without saddle bags. All easily changed within 1-2 min. When I tour, I usually remove it all when I get to my destination to clean up the look while puttin' 'round the local area.
Hope this helps.
The saddlebags go on the outer portion of the mounts correct?
Old Jan 13, 2012 | 12:50 PM
cbky71's Avatar
cbky71
Much appreciated!!!!!!!!!!!! That clears it up completely. Just left the hardware store and bought 3/8 threaded rod some nuts and other stuff. I think I can rig this up thanks to your pictures!!!
Old Jan 13, 2012 | 12:53 PM
cbky71's Avatar
cbky71
Hope this helps.
Very nice setup ya got.
Old Jan 13, 2012 | 01:08 PM
Harley Tim's Avatar
Harley Tim
correct. The inner ones are the docking point for the sissy bar/luggage rack... everything is set up w/QD. works great! Those little ***** inside the bag in the aft position are what makes them "quik detachable". By pulling out on them, and rotating them down, it moves that "L" shaped locking devise out of the way, allowing the bag to be moved back slightly, and removed.
Old Jan 13, 2012 | 01:29 PM
Harley Tim's Avatar
Harley Tim
You're welcome,... glad that cleared it up for you. Be sure to use some blue lock-tight once you get it all sorted out.
Anything else?....Just ask....
byersmtrco
Nov 1, 2018 03:10 PM
kino44
Dec 14, 2015 08:24 AM
Tickface
EVO
Jun 29, 2013 10:19 AM
blueangel73
Sep 19, 2011 07:16 PM
Blackbull
Jul 16, 2011 10:44 PM
